Type 'CommandMethod' is not defined.
tcorey
Mentor Mentor
Message 1 of 9
tcorey
I installed VS 2010 Express and then installed ObjectARX SDK 2013.
I can start a project, but in myCommands.vb I get the message above. It's going to be difficult to continue if any commands I create have a 0% chance of working.
Does anyone know why I would get this error even though I am able to start a project using the AutoCAD Plug-in.
I have already uninstalled and re-installed VisualStudio and ObjectArx.
Any ideas?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Replies (8)
Message 2 of 9
Hallex
Hope you added these references:
Imports Autodesk.AutoCAD.Runtime '<-- this one is to call CommandMethod
Imports Autodesk.AutoCAD.DatabaseServices
 Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.EditorInput
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 3 of 9
tcorey
Yep, all the references are there. Any other ideas?
I double-checked my folders for acmgd.dll and acad.exe and those are correct.
Tim Corey
Redding, CA
Message 4 of 9
Alfred.NESWADBA
does _NETLOAD tell you any problems?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 5 of 9
andrewpuller3811
Have you got a reference to AcCoreMgd.dll ?
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 11
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2023
Message 6 of 9
tcorey
That was it, ACCoremgd.dll. I loaded that reference and I'm off and running.
Thanks for the help!
Tim Corey
Redding, CA
Message 7 of 9
Alfred.NESWADBA
How were you able to compile your project with success?
Ohh, or haven't you set "Option Strict" active? If so, set it to yes and you will get errors while writing code and at least when compiling your source. That saves you a lot of time!
- alfred -
Alfred NESWADBA
Message 8 of 9
tcorey
Thanks.
Tim Corey
Redding, CA
Message 9 of 9
s_saravanaselvam
Observer
Observer
check your .net version
