Trying to rotate a plotted drawing
I am trying to rotate a drawing that is suppose to be plotted on ANSI_full_bleed_D_(34.00_x_22.00_Inches). The current code works, except that it keeps plotting on a portrait landscape. I have tried the .PlotRotation = ac90degrees command but with no luck.
Private Sub PlotToPdf(CurrentCADfile As AcadDocument, pdfFile As String)
    Dim ACADLayout      As ACADLayout
    'Create a new plot configuration with all needed parameters
'    Set ptObj = dwg.Plot
'    Set ptConfigs = dwg.PlotConfigurations
    Set ACADLayout = CurrentCADfile.ModelSpace.Layout
            ACADLayout.StyleSheet = "monochrome.ctb"                                      'Print in Black and White
            ACADLayout.PlotRotation = ac90degrees ' " landscape" 'Not working
            ACADLayout.ConfigName = "DWG To PDF.pc3"                                      'Using this printer
            ACADLayout.CanonicalMediaName = "ANSI_full_bleed_D_(34.00_x_22.00_Inches)"    'PDF format using this size
            ACADLayout.StandardScale = acScaleToFit
            ACADLayout.PlotType = acExtents                                               'If your drawing has no objects, ZoomExtents displays the drawing limits
            ACADLayout.CenterPlot = True                                                  'Center the plot
    Set currentplot = CurrentCADfile.Plot
        ''Convertion step
        currentplot.PlotToFile pdfFile 'Plots to a file. PlotToDevice  - Plots to a plotter or printer.
'        currentplot.DisplayPlotPreview
'        ThisDrawing.SetVariable "BACKGROUNDPLOT", 0
'        ThisDrawing.SetVariable "BACKGROUNDPLOT", backPlot '
    Debug.Print pdfFile
'    If currentplot.Plot.PlotToDevice Then
'        MsgBox "Layouts successfully plotted." 'Acad Quit here
'    End If
End Sub
norman.yuan
Are you saying that with or without this line
the output is the same. Or, have you tried ac0degree or ac180degress?
But, IMO, you should try to set PlotRotation AFTER setting ConfigName and CononicalMediaName properties. That is:
            '' ACADLayout.PlotRotation = ac90degrees ' comment this out
ACDDLayout.PlotRotation = ac90degree ACADLayout.StandardScale = acScaleToFit ACADLayout.PlotType = acExtents ACADLayout.CenterPlot = True
Norman Yuan
Drive CAD With Code
Just tried that now. Unfortunately, that didn't solve it. I also tried adding the "Regen" command afterwards to see if that might help, but it didn't. Here's my latest code so far. Thanks for helping out!
    CurrentCADfile.Regen acActiveViewport
norman.yuan
Well, I tried this code that worked perfectly (i.e. changed the plot rotation as expected):
Option Explicit
Public Sub PlotTest()
    Dim backPlot As Integer
    backPlot = ThisDrawing.GetVariable("BACKGROUNDPLOT")
    On Error Resume Next
    PlotToPdf ThisDrawing, "D:\Temp\TestDwgPlot1.pdf", ac0degrees
    PlotToPdf ThisDrawing, "D:\Temp\TestDwgPlot2.pdf", ac90degrees
End Sub
Private Sub PlotToPdf(currentDwg As AcadDocument, pdfFile As String, plotRotation As AcPlotRotation)
    Dim myLayout As ACADLayout
    Dim currentPlot As AcadPlot
    Set myLayout = currentDwg.ModelSpace.Layout
    myLayout.StyleSheet = "monochrome.ctb"
    myLayout.plotRotation = plotRotation
    myLayout.ConfigName = "DWG To PDF.pc3"
    myLayout.CanonicalMediaName = "ANSI_full_bleed_D_(34.00_x_22.00_Inches)"
    myLayout.StandardScale = acScaleToFit
    myLayout.PlotType = acExtents
    myLayout.CenterPlot = True
    Set currentPlot = currentDwg.Plot
    currentPlot.DisplayPlotPreview acFullPreview
    If currentPlot.PlotToFile(pdfFile) Then
        MsgBox pdfFile & " generated successfully."
End Sub
The code is almost the same as yours. HOWEVER, I did rename the variables, such as ACADLayout, which might be problematic because of being the same as class AcadLayout
Norman Yuan
Drive CAD With Code
That will do it!
