Trouble using keywords in PICK method with MDT5
Message 1 of 11
I can't get the pick method to except keywords. It keeps returning "invalid
entity" when I enter a keyword.
Any ideas?
Replies (10)
Message 2 of 11
Hi Wayne,
The following works for me (assuming your already connected to Acad/MDT).
Dim oMCADUtility As McadUtility
Dim oUserPick As McadPick
Dim oPickPart As McadComponent
Set oMCADUtility = oMCADApp.ActiveDocument.Utility
Set oUserPick = oMCADUtility.Pick("Select Part", mcComponent)
Set oPickPart = oMCADUtility.GetObjectFromPick(oUserPick)
Its probably the mcComponent (in the example) that's fouling you up. As far
as I know the "CreatePickObject" method is still broken. If your trying to
iterate through a selection loop and re-using a single pick, you've got your
work cut out for ya. I get power exits everytime I use that method. As far
as I can tell its the only way to make a single pick and then re-use the
pick to select a different object. I hope someone else has a better answer.
Gary
Message 3 of 11
Gary,
Your example does not show the use of keywords. I have attached a sample
of the code I am having trouble with.
The actual error I'm getting is, "Instance does not exist." The error occurs
when I try entering a keyword. The command doosn't want to except keywords.
This doesn't kill the command however.
Thanks for your help.
Wayne
"Gary McMaster" wrote in message
news:65CB27EA889586E58E47AE72B57F9599@in.WebX.SaUCah8kaAW...
> Hi Wayne,
far
your
answer.
> Gary
Message 4 of 11
Wayne,
I tried your example, and many variations thereof, and couldn't get it to
work either. It certainly doesn't seem to work as described in the help.
Maybe it's a side effect of the broken CreatePickObject method. It seems to
follow that the Pick method would make use of the CreatePickObject method,
at least in part.
Gary
Message 5 of 11
Thanks for help. Do you know another place where I can dirrect this issue?
Wayne
news:E53697E1950CCB70BADC0FA148D507BE@in.WebX.SaUCah8kaAW...
> Wayne,
to
> at least in part.
> Gary
Message 6 of 11
I wish I did. I often run into similar problems. If I can't get an answer
here, or in the help file, I try plan "B".
Gary
Message 7 of 11
What's plan "B"?
news:0BD44B8254CD63DF4F84D513F0064122@in.WebX.SaUCah8kaAW...
> Gary
Message 8 of 11
Whatever hacked workaround I can come up with.
Message 9 of 11
Guys
I may be missing the issue, but I just started a new drawing made a default
part, loaded the dvb, and run it. At the prompt I typed in Part1_1 and it
returned successful. Is that what you were trying to get?
Kent Keller
Check out the Mechanical Desktop FAQ @
http://mymcad.com/
"W Massey" wrote in message
news:793BBACB1F3F6C8367C7CCB3DBD82A03@in.WebX.SaUCah8kaAW...
> Gary,
> Wayne
Message 10 of 11
Sorry, It would help if I looked thru the code first and saw what you were
trying to get it to do. I agree with you guys, it appears busted in the
mcComponent version.
This doesn't work
Set pick = util.pick("Select component", mcComponent, , , "Word", KWused)
This does work
Set pick = util.pick("Select Profile to loft", mcSketch, , , "Loft", KWused)
Kent Keller
http://mymcad.com/
"Kent Keller" wrote in message
news:04F33D6C72B3D26227277ADA7D8BC67B@in.WebX.SaUCah8kaAW...
> Guys
> Kent Keller
> http://mymcad.com/
> > Gary,
> > Wayne
Message 11 of 11
Thanks, that gives me an idea.
news:549933CC4D084CC60066196BD82C827C@in.WebX.SaUCah8kaAW...
> This doesn't work
KWused)
> This does work
KWused)
> Kent Keller
> http://mymcad.com/
> > Guys
default
it
> > Kent Keller
> > http://mymcad.com/
> > > Gary,
sample
occurs
keywords.
> > > Wayne
