Trim entities
Trim entities
Trim entities
I want to trim some entities including line, circle and hatch. I used sendcommand to trim all entities except hatch. I want to trim everything after the red jog line. Some hatches are associated and some not.
Screenshot_1.pngEven manually, you have to click on a line of the hatch to trim it. That makes it impossible to use sendcommand. I thought about using GetBoundingBox and click that point but I don't think I can use those coordinates in sendcommand.
I hope someone can find a solution to this problem.
Hi @Anonymous
I Don't have the solution for you problem, but I have a similar problem. Since it's been a while, I was wondering if you've been able to solve the problem yourself? If so, would you like to share your solution here?
