TreeView control
TreeView control
TreeView control
Hi all,
Does somebody know/have a tutorial/example about how to modify (add/remove)
new nodes and labels in a TreeView Control? When I press F1 and ask for
help, I get the attached message. I would like to learn about the properties
and methods of this control. Some chunks of code could be very useful too.
Thanks in advance,
Constantin
Constantin, here is a short example I put together, it should get you
started (see attachment). As for locating help files - I have never seen any
support documentation for the tree view.
Best Regards,
Jacob Dinardi
Constantin GHERASIM wrote in message
news:D00D873F9F4E5550867B0E173595CF81@in.WebX.maYIadrTaRb...
Hi all,
Thanks in advance,
Constantin
There's some good info on the "Treeview" control here:
http://msdn.microsoft.com/library/default.asp?URL=/library/devprods/vs6/vbas
ic/vbcon98/vbconusingtreeviewcontrol.htm
Gary
I don't see a TreeView Control in "Microsoft Forms 2.0 Object Library",
(C:\WINDOWS\SYSTEM\FM20.DLL). I do see one in
"Microsoft Windows Common Controls 6.0 (SP3)",
(C:\WINDOWS\SYSTEM\MSComCtl.OCX). I see a Help file for the latter in
C:\WINDOWS\HELP\Cmctl198.chm.
John Goodfellow
irtf'nm
use 'microtouch' in address to email
"Constantin GHERASIM" wrote in message
> Hi all,
(add/remove)
properties
> Thanks in advance,
> Constantin
Thanks to each and everyone of you... I will take a closer look to the
posted material.
Constantin 🙂
> Hi all,
(add/remove)
properties
> Thanks in advance,
> Constantin
