Translate a drawing
Translate a drawing
Translate a drawing
I have a project to create a simple program with a database under Excel.
Under excel i Have two columns. One with text in French and a second with text in English. There is almost 300 lines under excel only.
The objective of the program under Autocad VBA is to replace each attributes and texts in french by the equivalent text in english.
I don't think i will have trouble to communicate with excel but I don't know how to check each attributes and text.
Can you help me ?
Mfauxock, this will give you a starting point. The code will find all Attributes and text in your drawing and display the text string.
Sub GetAttribValue()
Dim objBlkRef As AcadEntity
Dim objSelSet As AcadSelectionSet
Dim Atts As Variant
Dim iCount As Integer
Dim I As Integer
Dim varData(0) As Variant
Dim intType(0) As Integer
varData(0) = "INSERT,TEXT"
intType(0) = 0
Set objSelSet = ThisDrawing.PickfirstSelectionSet
objSelSet.Select acSelectionSetAll, filtertype:=intType, filterdata:=varData
For Each objBlkRef In objSelSet
'if attribute
If objBlkRef.ObjectName = "AcDbBlockReference" Then
If objBlkRef.HasAttributes Then
Atts = objBlkRef.GetAttributes
iCount = UBound(Atts)
Do While I < iCount + 1
MsgBox Atts(I).TextString '<---- the serch in database will go here
I = I + 1
Loop
'if text
If objBlkRef.ObjectName = "AcDbText" Then
MsgBox objBlkRef.TextString '<---- the serch in database will go here
Next objBlkRef
End Sub
I didn't though I will have so much Thanks a lot It is what I was looking for !!
You are welcome
