Tiled Documents in MDI
Can anyone help me with tiling document windows in the MDE?
Jim
Use SendCommand (in A2K) to drive the Syswindows command.
Get free software and more at:
http://msnhomepages.talkcity.com/protectionfault/foquendo
"James A. Bish" wrote in message
news:87kt6n$aa55@adesknews2.autodesk.com...
> Jim
From the Visual Basic Help Files of VB Design
http://vbdesign.hypermart.net/cadpages/
Hi James,
Are you up to using the Win32API? This is set to tile Horizontal, but the
constants are there to cascade, or tile vertical...
Place this code in a standard module:
'Begin code block
Option Explicit
'From VB Design!
Public Declare Function SendMessage Lib "user32" Alias "SendMessageA" (ByVal
hwnd As Long, ByVal wMsg As Long, ByVal wParam As Long, lParam As Any) As
Long
Public Declare Function FindWindow Lib "user32" Alias "FindWindowA" (ByVal
lpClassName As String, ByVal lpWindowName As String) As Long
Declare Function GetWindow Lib "user32" (ByVal hwnd As Long, ByVal wCmd As
Long) As Long
Public Const WM_MDICASCADE = &H227
Public Const WM_MDITILE = &H226
Public Const MDITILE_HORIZONTAL = &H1
Public Const MDITILE_SKIPDISABLED = &H2
'You can combine skip disabled with any of the others!
Public Const MDITILE_VERTICAL = &H0
Public Const GW_CHILD = 5
Public Sub TileDwgs()
Dim lngHwnd As Long
Dim lngMDIHwnd As Long
lngHwnd = FindWindow(vbNullString, Application.Caption)
lngMDIHwnd = GetWindow(lngHwnd, GW_CHILD)
SendMessage lngMDIHwnd, WM_MDITILE, MDITILE_HORIZONTAL, 0
End Sub
'End Code Block
Randall Rath
VB Design
So THAT'S the step I kept missing. I knew the API could cascade the windows
but it never occurred to me to use anything other than main application
window. Every time I tried to arrange the windows, nothing happened. Thanks
Randall.
"Randall Rath" wrote in message
news:87lpk2$edi3@adesknews2.autodesk.com...
> Hi James,
> 'Begin code block
> Option Explicit
> 'From VB Design!
(ByVal
> Long
> Long) As Long
> Dim lngHwnd As Long
> End Sub
> 'End Code Block
> Randall Rath
> VB Design
