thisdrawing.utility.prompt .... overwriting
Message 1 of 9
hi
i am trying to use the thisdrawing.utitity.prompt, whenever i run this from
the vba editor it works, but if i run the routine from a toolbar / lisp the
prompt seems to overwrite the previous command line, not start a new line..
'code:
ThisDrawing.Utility.Prompt vbNewLine & "Current settings: Opening = " &
sSaveAndClose & ", Filter = " & sDrawingFilter & ", Xref path = " &
sXrefPath & vbNewLine
ThisDrawing.Utility.InitializeUserInput 1, "Previous Next Text Xref
Options"
sDrawingOption = ThisDrawing.Utility.GetKeyword(vbNewLine & "Open
drawing options [Previous/Next/via Text/Xref/Options]: ")
any help would be great
cheers
mark
Replies (8)
Message 2 of 9
Try vbCrLf in lieu of vbNewLine
I've never heard of vbNewLine but if it's the same as vbCR then that is the
behaviour you get
hth
Mark
"Mark Dubbelaar" wrote in message
news:[email protected]...
> hi
from
the
line..
> 'code:
> Options"
> cheers
> mark
Message 3 of 9
i've tried the vbcrlf, but get the same effect... i looked vbcrlf in the
help and found the vbnewline function, the help says they are the same, i
just found the vbnewline easier to understand then vbcrlf
i've also tried the vbcr, but ended up with the same results
mark
"Mark Propst" wrote in message
the
> behaviour you get
> hth
> Mark
> > hi
> from
> the
> line..
> > 'code:
> > Options"
> > cheers
> > mark
Message 4 of 9
weird
like you said from the editor it works fine
I shortened it to
Sub TEST()
ThisDrawing.Utility.prompt vbNewLine & "Current settings: Opening = " &
vbNewLine
Options"
ThisDrawing.Utility.GetKeyword (vbNewLine & "Open drawing options
End Sub
and called it from lisp via:
(defun c:test()
(macro "testprj.dvb" "testprompt" "test")
which basically just calls the usual dvb!module.macro syntax
and the output now gives me a double line
thus:
Command: test
_.-VBARUN
Macro name: testprompt.test
Open drawing options [Previous/Next/via Text/Xref/Options]:
Open drawing options [Previous/Next/via Text/Xref/Options]: x
Command:
Command: test
_.-VBARUN
Open drawing options [Previous/Next/via Text/Xref/Options]: p
Command:
Command: test
_.-VBARUN
Open drawing options [Previous/Next/via Text/Xref/Options]: n
Command:
so it's not overwriting the previous line, it's writing twice???
no idea why
sorry no help
good luck
Mark
Message 5 of 9
Mark,
I was wondering if you figured it out.
I now notice that the project I'm working on also has a weird effect with
the prompts (imo)
I get that double prompt I mentioned with your code even with a getpoint
prompt:
this line:
ws.inspt = oDoc.Utility.GetPoint(, "Pick point for weld sym " & vbCrLf)
yields at command line:
Command: weld
_.-VBARUN
Macro name: modWeldSym.WeldSym Pick point for weld sym
so now I'm wondering how to suppress prompts like the above
of the above lines I wouldn't want to see:
_.-VBARUN
all I would want to see is:
Command: weld
it's like having to add a (princ) statement to the end of a lisp routine,
not to see the return value
so the question is what is the equivalent of (princ) in vb?...even though
the getpoint was not the last line in the sub (which is what would get
returned in a lisp prog) it seems to be the line that's returning a value to
the autocad command line.
very weird (only because of my ignorance I guess)
any ideas?
other Mark
> hi
Message 6 of 9
mark,
i haven't yet figured out the problem of double lines, and lines overwriting
each other... i've had a look at you post on 21/06/03 and would be
interested in how the vla-runmacro is going.. i haven't been able to find
any info on this function...
on another matter, i've been having some similar problems with lisps... for
some reason, if the lisp is compiled to a .fas file, any (princ
"\nwhatever") or (prompt "\nwhatever") does not show up.... but if i were to
run the source file (ie the .lsp file) it seems to work fine. Below is a
sample code of what i tested this on... i'll post this on the general 2004
newsgroup as well
;start code
;;Created: Mark Dubbelaar
;internal error
(defun LISPERROR (s)
(setq *CURR_OSNAP
nil
COPYSET nil
(setq *error* olderror)
(setq olderror nil)
(command "undo" "end")
(princ "\n LISP CANCELLED / ERROR")
(princ "\n SETTINGS HAVE BEEN RESET")
(princ "\n ")
(princ)
;program
(defun C:CO (/ *CURR_OSNAP olderror COPYSET)
(setq *CURR_OSNAP (getvar "osmode"))
(setq olderror *error*)
(setq *error* LISPERROR)
(setvar "cmdecho" 0)
(command "undo" "begin")
(setvar "osmode" 0)
(setq COPYSET (ssget))
(if (/= COPYSET nil)
(command "copy" COPYSET "" "0,0" "0,0")
(prompt "\nNothing selected!")
) ;if
(setvar "osmode" *CURR_OSNAP)
(setq olderror nil)
(princ)
(princ)
;end code
cheers
mark
> Mark,
> the prompts (imo)
> prompt:
> this line:
> Command: weld
> _.-VBARUN
> _.-VBARUN
> Command: weld
to
> any ideas?
> other Mark
> > hi
Message 7 of 9
results at textscreen:
Command: testmacro
Try test 1Initializing VBA System...
Loading VBA startup file...
Open drawing options [Previous/Next/via Text/Xref/Options]: o
Command:
Try test 2_.-VBARUN
Macro name: testpromptprj.dvb!testprompt.Test1
Command:
lisp code to produce above:
(defun C:TestMacro()
(vl-load-com)
(setq acadObj (vlax-get-acad-object)) ;;; get the currently active dwg
; Test Macro
(princ"\nTry test 1")
(defun c:Test1 ()
(setq fname "testpromptprj.dvb!testprompt.Test1")
(vla-runmacro acadObj fname)
(princ)
(C:test1)
(princ"\nTry test 2")
; Test Macro
(defun c:Test2 ()
(vl-vbarun fname)
(princ)
(C:test2)
contents of vba macro
Option Explicit
Sub TEST1()
vbNewLine
Options"
ThisDrawing.Utility.GetKeyword (vbCr & "Open drawing options
End Sub
so it seems like vla-runmacro 'works', but I'd still like to know how to
avoid the:
" Initializing VBA System...
Loading VBA startup file..."
lines
maybe something with vbcr to erase the previous messages, but havent' gotten
it to work yet.
> mark,
overwriting
i found a few posts on google for it. seems vl-vbarun resets fileDia sys
var to 0 as well as the weird prompt phenomena. Amazingly I haven't found
any posts on google complaining about this exact problem!!! How is that
possible? Are we the only two guys for whom this doesn't work? Amazing.!
good luck
Mark
Message 8 of 9
mark
i've just come across maybe a bug in the vla-runmacro function... in the vba
routine i am writing (where this line comes from: Open drawing options
[Previous/Next/via Text/Xref/Options]:) the routine opens up drawings
depending on what option the user chooses.... the problem is that when i use
the vla-runmacro, autocad opens the drawing up, but it then returns to the
previous drawing ie the one where i ran the open drawing routine from....
any suggestions, i think i might post this on the lisp newsgroup as well
cheers
mark
> Command: testmacro
> Command:
> Try test 2_.-VBARUN
> Command:
> (vl-load-com)
> ; Test Macro
> (defun c:Test1 ()
> (princ)
> (C:test1)
> ; Test Macro
> (defun c:Test2 ()
> (vl-vbarun fname)
> (princ)
> (C:test2)
> Option Explicit
> Sub TEST1()
> vbNewLine
> Options"
> End Sub
> avoid the:
> lines
gotten
> it to work yet.
> > mark,
> overwriting
find
> good luck
> Mark
Message 9 of 9
You may find this helpful with getting the prompts to display when launching vba from lisp
http://forums.autodesk.com/t5/Visual-Basic-Customization/Lisp-calls-VBA-Utility-Prompt-does-not-show...
