Text strings
Text strings
Text strings
I am having a problem with a text string cutting off the letter 'E' It
doesnt seem to cut off any other letter.. and only cuts of 'E' if it is the
last letter in the string..
please someone explain this to me?
Nate
Is this within VBA code?
If so, post relevant portions of the code.
"Nate" wrote in message
news:EBF11204476BFA8CF810C582F8C55D3F@in.WebX.maYIadrTaRb...
the
> Thanks,
> Nate
Yes.. I thought I did sorry.. 🙂
The text that cuts off trailing e's is the 'cgPoint.FullDescription'
which you may guess is an AeccPoint
Dim Text As AcadText
Dim Textstring As String
Textstring = (Format(StationEq, "00+00.00")) & " " & (Format(Offset,
"00.00" & " " & cgPoint.FullDescription))
Set Text = ThisDrawing.ModelSpace.AddText(Textstring, Placepoint,
txtHeight)
Text.Rotate Placepoint, (direction - 1.57)
Text.Update
"TomD" wrote in message
news:107F36234ED54A7C5200D4BEF1CED4B5@in.WebX.maYIadrTaRb...
> the
> > Thanks,
> > Nate
Sorry I don't have time to check my answer for correctness, but at first
glance it looks like the paren's are messed up on your second FORMAT.
Maybe:
(Format(Offset, "00.00") & " " & cgPoint.FullDescription)
lol..
Bingo... Thanks a bunch..
"James Belshan" wrote in message
news:439415DDE0B215C6CF923F933C6AB914@in.WebX.maYIadrTaRb...
> Maybe:
