Text in layout with vba
I have a layout and i need to get some text in the layout, such as my name, street,...
But i don't know how i need to do this. How can i insert text ( multiple lines)
I hope somebody can help me,
here's the AutoCAD ActiveX and VBA Reference example for inserting a MText that you can adapt to your needs
Sub Example_AddMtext()
    ' This example creates an MText object in model space.
    Dim MTextObj As AcadMText
    Dim corner(0 To 2) As Double
    Dim width As Double
    Dim text As String
    corner(0) = 0#: corner(1) = 10#: corner(2) = 0#
    width = 10
    text = "This is the text String for the mtext Object"
    ' Creates the mtext Object
    Set MTextObj = ThisDrawing.ModelSpace.AddMText(corner, width, text)
    ZoomAll
End Sub
how to put the tekst in a layoutpaper? now its in modelspace. but when i do thisdrawing.modelspace to thisdrawing.layouts it gives a error...
Imports Autodesk.AutoCAD.Interop.Common
Public Class Class1
Public AcadApp As Autodesk.AutoCAD.Interop.AcadApplication
Public AcadDoc As Autodesk.AutoCAD.Interop.AcadDocument
<Autodesk.AutoCAD.Runtime.CommandMethod("DanLinea")> Public Sub Inptext()
AcadApp = GetObject(, "Autocad.Application.20.1")
AcadDoc = AcadApp.ActiveDocument
Dim Pt1(2), Pt2(2) As Double
Pt1(0) = 0
Pt1(1) = 1
Pt1(2) = 0
Pt2(0) = 10
Pt2(1) = 0
Pt2(2) = 0
Dim ObjText1 As AcadText
Dim ObjText2 As AcadText
ObjText1 = AcadDoc.ModelSpace.AddText("ModelSpace", Pt1, 10) 'Inserts Text Into Model
ObjText2 = AcadDoc.PaperSpace.AddText("PaperSpace", Pt1, 10) 'Inserts Text Into Layout
AcadApp.Application.ZoomExtents()
End Sub
End Class
kasperwuyts
Instead of 'thisdrawing.modelspace'
Use 'thisdrawing.paperspace'
This will add the text to the currently active layout PROVIDED a layout is active.
Another solution is to use:
'thisdrawing.activelayout.block'
-> Which will use the currently active sheet, whether is it modelspace or paperspace.
Another option is:
'thisdrawing.layouts(<index number>).block'
-> this will use a very specific layout, not per se the one active. Ofcourse you replace <index number> with the correct integer (depends on the layout).
Kasper
Best regards
Kasper Wuyts
_______________________________________________________________________________
If this post solves your problem, clicking the 'accept as solution' button would be greatly appreciated.
