Testing code formatting appearance
Message 1 of 8
I've hears from Autodesk that the code formatting for newsreaders has been implemented.
Here's some code (from Frank Oquendo's Curve Class) posted via the web site as plain text and formatted with the website recommended squiggly bracket code squiggly bracket.
We soon see how it looks in a newsreader as well as on the web
{code}
Public Function GetPointAtDistance(Dist As Double) As Variant
Dim RetVal As Variant, Pt(0 To 2) As Double
Dim i As Long
With clsVLAX
.SetLispSymbol "handle", oAcadEntity.Handle
.SetLispSymbol "dist", Dist
.EvalLispExpression "(setq lst (vlax-curve-getPointAtDist (handent handle) dist))"
RetVal = .GetLispList("lst")
.NullifySymbol "handle", "dist", "lst"
End With
For i = 0 To 2
Pt(i) = RetVal(i)
Next
GetPointAtDistance = Pt
End Function ' GetPointAtDistance
{code}
Laurie Comerford
Replies (7)
Message 2 of 8
Hi Laurie,
IT WORKS !!!!!!!!!!
Reply from Thunderbird.
Thank you at last Autodesk.
Laurie Comerford
laurie.comerford@cadapps.com.au wrote:
> Hi,
> {code}
> Dim i As Long
> With clsVLAX
> End With
> For i = 0 To 2
> Pt(i) = RetVal(i)
> Next
> {code}
> Regards,
> Laurie Comerford
Message 3 of 8
Laurie, now they have you talking to yourself! 🙂
I sent Eric Wright a big Thank you earlier! For those that don't know, Eric
is one of those Adesk employees whose job description includes trying to
keep us Discussion/News group users happy. I don't envy him at all.....
Thank you again, this time publicly, Eric!
Jeff
"Laurie" wrote in message
news:6207107@discussion.autodesk.com...
> Hi Laurie,
> IT WORKS !!!!!!!!!!
> Regards,
> Laurie Comerford
>> Hi,
>> been implemented.
>> {code}
>> Dim i As Long
>> With clsVLAX
>> handle) dist))"
>> End With
>> For i = 0 To 2
>> Pt(i) = RetVal(i)
>> Next
>> {code}
>> Regards,
>> Laurie Comerford
Message 4 of 8
Posted as plain text from ie8 Newgroup reader
{code}
//CodeHimBelongaKdub © June2009
[CommandMethod("testOPEN", CommandFlags.Session)]
static public void testyOpen()
DocumentCollection dm = AcadApp.DocumentManager;
Editor ed = dm.MdiActiveDocument.Editor;
PromptOpenFileOptions POFO = new PromptOpenFileOptions(
"Select a drawing file" );
POFO.InitialDirectory = "F:\\_KDUB_DEV";
POFO.Filter = "AutoCAD DWG Files|*.dwg|AutoCAD DXF Files|*.dxf";
POFO.DialogCaption = "Select a file, dude.";
PromptFileNameResult pr = ed.GetFileNameForOpen(POFO);
if (pr.Status == PromptStatus.OK)
dm.Open(pr.StringResult);
{code}
/// kdub
wrote in message
news:6207123@discussion.autodesk.com...
> Hi,
> implemented.
> {code}
> Dim i As Long
> With clsVLAX
> handle) dist))"
> End With
> For i = 0 To 2
> Pt(i) = RetVal(i)
> Next
> {code}
> Regards,
> Laurie Comerford
Message 5 of 8
kerry_w_brown
Posted as plain text from forums
{code}
{code}
/// kdub
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Message 6 of 8
kerry_w_brown
I wonder how much it would cost to have the code pane (and text pane) the FULL width of the forum interface
... to help eliminate the squished presentation ..
Message 7 of 8
arcticad
Lets fix all the current problems, before we make new ones.
Although I would like it to fit the size of the screen.
(defun botsbuildbots() (botsbuildbots))
Message 8 of 8
Hi everyone,
I have a different issue that i need to add my option e.g. "SourceSafe" in the lookin dropdown of open Dialog. and on seletction of this link i will get the list of files from sourcesafe and load them on the open dialog for the user to select.
Please guide me in case if anyone has idea on this.
Vikas Edited by: vikashajela on Apr 20, 2010 9:13 AM
