Test if an Excel file is open
I am trying to write a function that checks if an Excel workbook is open (read only or not), and if it’s open assign a variable to it.
I have found many examples of how to test if an Excel workbook is open from excel VBA, but can’t get it to work in AutoCad VBA. Any help in getting this code to work in Autocad would be appreciated.
This is the Testing function I have so far:
Function WorkbookOpen(WorkBookName As String) As Boolean
' returns TRUE if the workbook is open
WorkbookOpen = False
Dim Wbk As Workbook
'On Error GoTo WorkBookNotOpen
If Len(Excel.Application.Workbooks(WorkBookName).Name) > 0 Then
MsgBox "WorkbookOpen = True", , "Testing MsgBox"
WorkbookOpen = True
Exit Function
MsgBox "WorkbookOpen = False", , "Testing MsgBox"
WorkBookNotOpen:
End Function
Kai
look into GetObject and CreateObject
arcticad
This will let you check if a file is in use
{code}
Function Example()
Dim FileName As String
FileName = "c:\text.txt"
Select Case isFileInUse(FileName)
Case False
MsgBox "NOT in use!"
Case True
MsgBox FileName & " is in use!"
Case -2
MsgBox "Unable to determine if file " & FileName & " is in use!"
Case -3
MsgBox FileName & " Not Found:"
Case Else
' So Long and Thanks for the Fish
End Select
End Function
Function isFileInUse(ByVal sFileName As String) As Integer
'Returns False (0) if file exists and can be opened
'Returns True (-1) if files exists but cannot be opened
'Returns -2 if file exists but no file handles available
'Returns -3 if file does not exist
Dim nFileNum As Integer
isFileInUse = False 'assume not in use
If Dir$(sFileName, ATTR_NORMAL) = "" Then GoTo noSuchFile
On Error GoTo noFileHandles
nFileNum = FreeFile()
On Error GoTo inUse
Open sFileName For Binary Access Read Lock Read Write As nFileNum
Close nFileNum
GoTo endFunc
noSuchFile:
isFileInUse = -3
Exit Function
inUse:
isFileInUse = True
Exit Function
noFileHandles:
isFileInUse = -2
Exit Function
endFunc:
End Function
{code}
(defun botsbuildbots() (botsbuildbots))
