Table cell data format
Hi there, i have created a table with 3 column, the first an second column is integer and the third column is the division of the other two.
=A1/B1
the problem is the output has a lot of trailing zero. I notice in autocad itself, you can select the cell, choose data format and change the precision. But how do i do it in vb?
Hi whtam,
When you write the data to the cell use the Format function to display
the number of decimal places you require.
MyFormattedString = Format(MyNumber, "#0.000")
Regards
Laurie Comerford
> =A1/B1
I set the cell value with
Table.SetText(0,2,"=A1/B1")
format doesnt work..
