Suggestion on open file diaolog
My situation is this...
I am trying to insert a block from a file (browse and pick)
I have found some sample code that opened a user form and then opened the
dialog box
But my problem is passing the file name back to my sub for the block
insert...
Any suggestions as to where to find some ideas?
Randy
dialog box
insert...
Randy
randy, what type of dialogbox did you open, is it a selfwritten one or the
windows commondialog or...
if it is the commondialog then you can return the ".FileName", it it's self
written, it would be more easy if we see your code.
- alfred -
In article ,
RBILLINGS@PREFERREDMFG.COM says...
> dialog box
> insert...
> Randy
The folling code is from userform1 (I kinda want to by pass this form and go
straight to the open file box)
Option Explicit
Private Declare Function GetOpenFileName Lib "comdlg32.dll" Alias
"GetOpenFileNameA" (pOpenfilename As OPENFILENAME) As Long
Private Type OPENFILENAME
lStructSize As Long
hwndOwner As Long
hInstance As Long
lpstrFilter As String
lpstrCustomFilter As String
nMaxCustFilter As Long
nFilterIndex As Long
lpstrFile As String
nMaxFile As Long
lpstrFileTitle As String
nMaxFileTitle As Long
lpstrInitialDir As String
lpstrTitle As String
flags As Long
nFileOffset As Integer
nFileExtension As Integer
lpstrDefExt As String
lCustData As Long
lpfnHook As Long
lpTemplateName As String
End Type
Public Function ShowOpen(Filter As String, _
InitialDir As String, _
DialogTitle As String) As String
Dim OFName As OPENFILENAME
'Set the structure size
OFName.lStructSize = Len(OFName)
'Set the owner window
OFName.hwndOwner = 0
'Set the filter
OFName.lpstrFilter = Filter
'Set the maximum number of chars
OFName.nMaxFile = 255
'Create a buffer
OFName.lpstrFile = Space(254)
'Create a buffer
OFName.lpstrFileTitle = Space$(254)
OFName.nMaxFileTitle = 255
'Set the initial directory
OFName.lpstrInitialDir = InitialDir
'Set the dialog title
OFName.lpstrTitle = DialogTitle
'no extra flags
OFName.flags = 0
'Show the 'Open File' dialog
If GetOpenFileName(OFName) Then
ShowOpen = Trim(OFName.lpstrFile)
Else
ShowOpen = ""
End Function
Private Sub cmdShowOpen_Click()
Dim Filter As String
Dim InitialDir As String
Dim DialogTitle As String
Filter = "Drawing Files (*.dwg)" + Chr$(0) + "*.dwg" + Chr$(0) + "All
Files (*.*)" + Chr$(0) + "*.*" + Chr$(0)
InitialDir = "H:\0blocks\HARDWARE"
DialogTitle = "Open a DWG file"
Label1.Caption = ShowOpen(Filter, InitialDir, DialogTitle)
End Sub
The following is from module1 where ***** should be the file name
Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(p1, ******, 1#, 1#, 1#,
angle)
randy,
it's not really beautiful, but should work:
userform1.Label1.Caption, 1#, 1#, 1#,
- alfred -
In article <3DFBF781A292C3D41B5EB4872169CD08@in.WebX.maYIadrTaRb>,
> Option Explicit
> lStructSize As Long
> hwndOwner As Long
> hInstance As Long
> lpstrFile As String
> nMaxFile As Long
> flags As Long
> lCustData As Long
> lpfnHook As Long
> End Type
> 'Set the filter
> 'Create a buffer
> 'Create a buffer
> 'no extra flags
> OFName.flags = 0
> Else
> ShowOpen = ""
> End If
> End Function
> End Sub
> angle)
problem is the variable from the show open does not pass back to the sub
didn't got it at my first look, sorry.
if calling api-functions you do have to set empty-values just for reserving
space for the api-function to fill in data.
so check at least all strings to be initalized like
OFName.lpstrFile = Space$(254)
i hope now it's ok and we have found all, - alfred -
In article , RBILLINGS@PREFERREDMFG.COM says...
