Subtracting one selection set from another?
I'm trying to delete everything in a drawing except for whatever is inside
of an area defined by a windowl, but run into the following problem:
' Create a new selection set with everything in it
Dim ssetObj As AcadSelectionSet
Set ssetObj = acadDoc.SelectionSets.Add("SSET")
Dim mode As Integer
mode = acSelectionSetAll
ssetObj.Select mode
' Create another selection set of the stuff that I want to keep
Dim ssetObjKeep As AcadSelectionSet
Set ssetObjKeep = acadDoc.SelectionSets.Add("KEEP")
mode = acSelectionSetCrossing
Dim corner1(0 To 2) As Double
Dim corner2(0 To 2) As Double
corner1(0) = 0.1938: corner1(1) = 0.21: corner1(2) = 0
corner2(0) = -0.1938: corner2(1) = -0.3025: corner2(2) = 0
ssetObjKeep.Select mode, corner1, corner2
' Subtract the "keeper" set from the main set
' The problem is with this next line. It says "invalid argument"
ssetObj.RemoveItems ssetObjKeep
' Delete everything in the main selection set
ssetObj.Erase
Is there an easier approach to this problem?
John S.
RemoveItems expects an array of AcadEntity objects, not an AcadSelectionSet.
Here's a helper routine for you. Include this in your project and change
this line of code:
to this:
ssetObj.RemoveItems ssArray(ssetObjKeep)
Here's the ssArray function:
Public Function ssArray(ss As AcadSelectionSet)
Dim retVal() As AcadEntity, i As Long
ReDim retVal(0 To ss.Count - 1)
For i = 0 To ss.Count - 1
Set retVal(i) = ss.Item(i)
Next
ssArray = retVal
End Function
Visit AcadXtreme for a chance to win a copy of AutoCAD LT 2000
Contest ends 5/26/00
http://www.acadx.com
"John Sauber" wrote in message
news:ef137c0.-1@WebX.SaUCah8kaAW...
> Dim mode As Integer
> ssetObj.Select mode
> ssetObj.Erase
> Thanks,
> John S.
That did the trick. Thanks much. Sorry for the duplicate posting. --
js
Frank Oquendo wrote in message
news:ef137c0.0@WebX.SaUCah8kaAW...
AcadSelectionSet.
> this line of code:
> to this:
> Next
> ssArray = retVal
> End Function
inside
> > Dim mode As Integer
> > ssetObj.Select mode
> > ssetObj.Erase
> > Thanks,
> > John S.
