Stuck on a drawing border question
Message 1 of 9
I am trying to change the text in a drawing border but I am having a little trouble.
I am trying to use and convert code from a text book example that I have.
For Each elem In ThisDrawing.PaperSpace
If elem.EntityName = "AcDbBlockReference" Then
If elem.Name = "Part_Number" Then
foundAttributes = True
Array1 = elem.GetAttributes
I have looked at sample drawing this code works on but I cannot link the name AcDbBlockReference" with anything - can anyone help me out.
Ian
Replies (8)
Message 2 of 9
First things first. Are you trying to modify the actual text value of an attribute within a block? If so, you need to find the block, first. Once you have that, if I remember correctly, you have to go through the two arrays (tag name/value name) and find the attribute tag you are trying to change. "montyzoomer" wrote in message news:[email protected]... >I am trying to change the text in a drawing border but I am having a little >trouble. > > I am trying to use and convert code from a text book example that I have. > > For Each elem In ThisDrawing.PaperSpace > If elem.EntityName = "AcDbBlockReference" Then > If elem.Name = "Part_Number" Then > foundAttributes = True > Array1 = elem.GetAttributes > > I have looked at sample drawing this code works on but I cannot link the > name AcDbBlockReference" with anything - can anyone help me out. > > Thanks > > Ian
Message 3 of 9
Tom
Yes I need to change the text value of the attribute within the block.
If I look at the sample and list the info of the block, I cannot see the reference name listed in the code yet it seems to be using the reference to find the block.
I'm confused
Message 4 of 9
> I'm confused I understand your confusion, believe me. ;) Please be aware that I'm not a VBA whiz, and take note of any posts critical of anything in the code I post. I can tell you that the snippets I'm posting work well, in our company's circumstances. These were written specifically for use here and most likely would need some amount of modification for your use. For finding the title block BLOCK, I use the following (note that this is a snippet from a routine that goes to each layout being plotted and retrieves information for storage in a database, no modifcation of the values was required.) Function GetTitleBlockInfo() As Variant '======================================================================== Dim sTitle1 As String, sTitle2 As String, sTitle3 As String Dim sDwgNum As String Dim vRet(3) As Variant Dim oLayout As AcadLayout, oLayBlock As AcadBlock Dim oEnt As AcadEntity Dim oBlkRef As AcadBlockReference Set oLayout = ThisDrawing.ActiveLayout Set oLayBlock = oLayout.Block For Each oEnt In oLayBlock If oEnt.ObjectName = "AcDbBlockReference" Then Set oBlkRef = oEnt Select Case oBlkRef.Name Case "cectb30x42sd", "cectb24x36sd" sTitle1 = GetAttTxtStr("TITLE_LINE_1", oBlkRef) sTitle2 = GetAttTxtStr("TITLE_LINE_2", oBlkRef) sTitle3 = GetAttTxtStr("TITLE_LINE_3", oBlkRef) sDwgNum = GetAttTxtStr("PROJ_NO", oBlkRef) & "-" & _ GetAttTxtStr("DWG_NO", oBlkRef) GoTo ValuesObtained Case "30x42 Title", "30-42 Title Block", "24x36 Title Block", _ "Cec Title Block", "30-42_TITLE" sTitle1 = GetAttTxtStr("TITLE_1", oBlkRef) sTitle2 = GetAttTxtStr("TITLE_2", oBlkRef) sTitle3 = GetAttTxtStr("TITLE_3", oBlkRef) sDwgNum = GetAttTxtStr("DWG_NO", oBlkRef) GoTo ValuesObtained Case Else sTitle1 = "": sTitle2 = "": sTitle3 = "" sDwgNum = "000000" End Select End If Next oEnt ValuesObtained: Set oBlkRef = Nothing Set oLayBlock = Nothing Set oLayout = Nothing vRet(0) = sTitle1: vRet(1) = sTitle2: vRet(2) = sTitle3 vRet(3) = sDwgNum GetTitleBlockInfo = vRet End Function The GetAttTxtStr function used in the above code is as follows: Function GetAttTxtStr(sTagString As String, oBlkRef As AcadBlockReference) As String Dim vAttArr As Variant Dim iAttCnt As Integer Dim sRet As String sRet = "" If Not oBlkRef.HasAttributes Then GetAttTxtStr = sRet: Exit Function vAttArr = oBlkRef.GetAttributes For iAttCnt = 0 To UBound(vAttArr) If vAttArr(iAttCnt).TagString = sTagString Then GetAttTxtStr = vAttArr(iAttCnt).TextString Exit Function End If Next GetAttTxtStr = sRet End Function Again, a side note: The GetAttTxtStr could certainly use some tweaks, but it works for here, so I didn't take it any further. It DOES have some potential problems, though. Hope that helps as opposed to hindering your grasp of the topic.
Message 5 of 9
Hi Ian Rather than looping thru all entities you would be better of creating a selection set and filtering for blocks called "Part_Number" in paperspace. You can then loop thru the selection set and access the attributes Something like this... Sub SelectBlocks() '=========================================== Dim ss As AcadSelectionSet Dim gpCode(1) As Integer Dim dataValue(1) As Variant Dim groupCode As Variant Dim dataCode As Variant Dim Blk As AcadBlockReference Dim Atts As Variant Dim i As Integer 'filter for blocks where name = "PART_NAME" gpCode(0) = 2: dataValue(0) = "PART_NAME" 'filter for entities in paperspace gpCode(1) = 67: dataValue(1) = 1 'assign filters to variant datatypes groupCode = gpCode dataCode = dataValue 'add selectionset to selectionsets collection Set ss = ThisDrawing.SelectionSets.Add("SS_SelectBlocks") 'select all entities and apply filter ss.Select acSelectionSetAll, , , groupCode, dataCode 'loop thru selection set For Each Blk In ss 'check if block has attributes If Blk.HasAttributes Then 'assign attributes to variant datatype Atts = Blk.GetAttributes 'loop thru attributes For i = 0 To UBound(Atts) Debug.Print Atts(i).TagString & ": " & Atts(i).TextString Next i End If Next Blk 'delete selectionset from selectionsets collection ss.Delete End Sub '================================================ -- Regards Tom Roberts __________________________ MechWest Design & Drafting Perth, Western Australia "montyzoomer" wrote in message news:[email protected]... >I am trying to change the text in a drawing border but I am having a little >trouble. > > I am trying to use and convert code from a text book example that I have. > > For Each elem In ThisDrawing.PaperSpace > If elem.EntityName = "AcDbBlockReference" Then > If elem.Name = "Part_Number" Then > foundAttributes = True > Array1 = elem.GetAttributes > > I have looked at sample drawing this code works on but I cannot link the > name AcDbBlockReference" with anything - can anyone help me out. > > Thanks > > Ian
Message 6 of 9
Thanks for that I will work through it to solve my code problem.
I am very impressed how helpful people are on the forum.
Thanks again
Regards
Ian
Message 7 of 9
Actually, if most of the entities reside in model space, then it may be faster to iterate just the entities on the layout. And it makes for much nicer code to boot. -- Bobby C. Jones "Tom Roberts" wrote in message news:41e5cf76$1_3@newsprd01... > Hi Ian > > Rather than looping thru all entities you would be better of creating a > selection set and filtering for blocks called "Part_Number" in paperspace. > You can then loop thru the selection set and access the attributes
Message 8 of 9
Tom
Any chance you could drop me a mail, I'd like to send you a border example that needs to be changed for your comments.
My address is
[email protected]
Message 9 of 9
TomD
Me Again !!!
You code seems to make sense until I reach Case "cectb30x42sd", "cectb24x36sd"
What does this represent, I would appreciate it if you could drop me a mail at
[email protected]
I would like to ask a couple more questions if you don't mind.
I feel like I am starting to get some where at last
Regards
Ian
