Specifying text size when inserting text with GetPoint ()
I insert text with the following code to insert text using the GetPoint() command:
Dim textObj As AcadText
Dim textString As String
Dim returnPnt1 As Variant
Dim height As Double
' Return a point using a prompt
returnPnt1 = ThisDrawing.Utility.GetPoint(, "Enter a point: ")
' Define the text object
textString = "Place object here"
height = 50
' Create the text object in model space
Set textObj = ThisDrawing.ModelSpace.AddText(textString, returnPnt1, height)
That works well but I'm trying to get the user to specify the text height in the command box not write it in the code as I have done above.
All help is appreciated.
might i suggest you add..
dim drawing as variant
if thisdrawing.getvar("tilemode") = 0 and
thisdrawing.getvar("cvport") = 1 then
set drawing = thisdrawing.paperspace
else
set drawing = thisdrawing.modelspace
end if
that way if the user wants to use your code while
in paperspace then he/she can
Dim textObj As
AcadText
point: ")
height = thisdrawing.utitlty.getreal(prompt here)
    Set
