Sorting list boxes in VBA
Does anyone have some code to sort list boxes in Autocad's VBA?
Thanks for your help
I use this for combo boxes, maybe you can adapt it to suit your needs:
calling procedure:
Dim vSort() As Variant
'sort combo box
vSort = Sort_Combo(cComboBox.List)
cComboBox.List = vSort
'Assumptions:
'Combo box passed in array of variants (0 to #, 0 to 9), with
'vArray(#,0) as the item to sort by
Public Function Sort_Combo(vArray As Variant) As Variant
Dim u As Long, l As Long, I As Long
Dim vTemp() As Variant
Dim vA As Variant, vB As Variant
Dim bSort As Boolean
bSort = False
vTemp = vArray
u = UBound(vArray, 1): l = LBound(vArray, 1)
Do
bSort = False
For I = l To u - 1
If vTemp(I, 0) <= vTemp(I + 1, 0) Then
'Debug.Print vTemp(i, 0) & " vs " & vTemp(i + 1, 0)
'this situation is ok
Else
'need to swap
bSort = True
vA = vTemp(I, 0)
vB = vTemp(I + 1, 0)
vTemp(I, 0) = vB
vTemp(I + 1, 0) = vA
'Debug.Print "chg'd " & vTemp(i, 0) & " w/ " & vTemp(i + 1,
0)
Next
Loop Until bSort = False
Sort_Combo = vTemp
End Function
Kevin
"William Jimenez" wrote in message
news:f13bcd3.-1@WebX.maYIadrTaRb...
I have drawings with thousands of layers and had to wait a long time to get
a combobox to sort using a vba bubble sort. I thought ADO might be able to
do it faster so I wrote this little ditty that sorts a collection. It could
probably be improved upon...
Public Function AdoSortComboBox(Combo_Box As ComboBox, Collection_Name As
Variant)
Dim ctr As Integer
Dim rs As ADODB.Recordset
Set rs = New ADODB.Recordset
With rs
.CursorLocation = adUseClient
.LockType = adLockBatchOptimistic
.Fields.Append "FIELD1", adVarChar, 80, adFldUpdatable
.Open
For ctr = 0 To Collection_Name.Count - 1
.AddNew
!Field1 = Collection_Name(ctr).name
.MoveNext
Next ctr
.Sort = "FIELD1"
.MoveFirst
Do Until rs.EOF
Combo_Box.AddItem rs!Field1
.MoveNext
Loop
.Close
End With
Set rs = Nothing
End Function
Also, make sure you have a reference to ADO.
Rogue
Although this might be overkill for your project, you could use a different control and let *it* do the sorting for you.
If you right-click on your toolbox and choose Additional Controls you can select Microsoft ListView Control which has a Sorted property. All you have to do is add the items to the control and by the time you've finished they're already sorted!
Regards
Wayne Ivory
IT Analyst Programmer
Wespine Industries Pty Ltd
