some product failed inastalation
amessage apper: net frame 4.5 dont find  -while there is net frame install on computer
017/9/9:15:53:17 jazz JAZEERA Download Aborted ACAD http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/ACAD_x64.t... 2017/9/9:15:53:17 jazz JAZEERA Install Autodesk® AutoCAD® 2015 Failed Download Failed, Installation aborted, Result=1603 2017/9/9:15:53:23 jazz JAZEERA Rollback Autodesk Content Service Language Pack Succeeded 2017/9/9:15:53:44 jazz JAZEERA Rollback Autodesk Content Service Succeeded 2017/9/9:15:54:06 jazz JAZEERA Rollback Autodesk Material Library 2015 - Base Image Library Succeeded 2017/9/9:15:54:48 jazz JAZEERA Rollback Autodesk Material Library 2015 Succeeded 2017/9/9:15:54:48 jazz JAZEERA Rollback DirectX Runtime Failed Failure is ignored, Result=1619 2017/9/9:15:54:48 jazz JAZEERA Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619 2017/9/9:15:54:49 jazz JAZEERA Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
Alfred.NESWADBA
welcome @Anonymous!
Download the installation files from Autodesk Virtual Agent >>>click<<<, then start the installation from that local file(s), using option "start as administrator", disabled antivirus.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
