simple userform code
I have asimple userform which consists of 2 option buttons (1 and 2) and one combo box (with choice of a b c and d). What i want to do is have user select one or the other option buttons (1 or 2) and the combobox display a and b if option button 1 selected or c and d if option button 2 selected.
Then user selects a or b or c or d and the result to be saved as an attribute for a block insertion. Can anyone supply mewith some code to do this
In the click event handler for each option button, clear the contents of the combobox and refill it with the appropriate values. -- There are 10 kinds of people: those who understand binary and those who don't.
how do i do that. i am just a new programmer
this is what i have at present
Private Sub OptionButton1_Click()
If OptionButton1 = True Then
Cbofirstend.AddItem "a"
Cbofirstend.AddItem "b"
Cbofirstend.ListIndex = 1
If OptionButton2 = True Then
'clear combobox'
Cbofirstend.AddItem "c"
Cbofirstend.AddItem "d"
End Sub
johnbortoli wrote: > this is what i have at present > > > Private Sub OptionButton1_Click() > If OptionButton1 = True Then > Cbofirstend.AddItem "a" > Cbofirstend.AddItem "b" > Cbofirstend.ListIndex = 1 > End If > If OptionButton2 = True Then > 'clear combobox' > > Cbofirstend.AddItem "c" > Cbofirstend.AddItem "d" > Cbofirstend.ListIndex = 1 > End If > End Sub Almost there. Separate the two blocks of code; the top section in OptionButton1_Click, the bootm section in OptionButton2_Click. Next, be sure to clear the Combobox before you start adding items to it. -- There are 10 kinds of people: those who understand binary and those who don't.
Private Sub OptionButton1_Click() With ComboBox1 .Clear .AddItem "A" .AddItem "B" .ListIndex = 0 End With End Sub Private Sub OptionButton2_Click() With ComboBox1 .Clear .AddItem "C" .AddItem "D" .ListIndex = 0 End With End Sub No need for any "if then" construct "johnbortoli" wrote in message news:22762525.1107500732407.JavaMail.jive@jiveforum1.autodesk.com... > this is what i have at present > > > Private Sub OptionButton1_Click() > If OptionButton1 = True Then > Cbofirstend.AddItem "a" > Cbofirstend.AddItem "b" > Cbofirstend.ListIndex = 1 > End If > If OptionButton2 = True Then > 'clear combobox' > > Cbofirstend.AddItem "c" > Cbofirstend.AddItem "d" > Cbofirstend.ListIndex = 1 > End If > End Sub
