Showing LW-PLine Length as the line is drawn
I am trying to create a VBA program to display total PLine length as I draw
the line. i.e.
Start the PLine command, pick a starting point.
As soon as I pick a second point I want a dialog box to come up to tell me
how long the line is up to that point.
After displaying the length, pick a third point for the PLine, and display
the new total length (not the last segment length).
Keep going, etc. till endpoint of line is created.
I've found a VB function to do the total length calculation, and created the
form in VBA to display the total length.
The problem seems to be 'Focus'. How do I change focus after displaying the
dialog so the user doesn't have to click 'OK' in the dialog every time he
picks a new point?
Miles Andrews
smilesfromnowhere at hotmail dot com
I'm a Delphi guy and don't know if VB implements SetForgroundWindow() from
then WinAPI. If not you can make the call directly using external calls to
WinAPI.
You'll have to find the hWnd for The drawing editor window and not the main
AutoCAD Window as it may not necessarily give focus to the user drawing the
pline.
The best way to do this would be to have a floating toolbar (modeless form)
displaying the calculated distance without having to dismiss it every time
you pick a point. How are you handling curves within the pline?
Hugo
"Hawk A. Loogie" wrote in message
news:[email protected]...
draw
> the line. i.e.
the
the
> picks a new point?
> Miles Andrews
Any ideas how I would create one of these?
Miles
"Hugo Guerrero" wrote in message
to
> WinAPI.
main
the
> pline.
form)
> Hugo
> draw
> > the line. i.e.
me
display
> the
> the
he
> > picks a new point?
> > Miles Andrews
I suppose VBA does not let you create modeless forms within AutoCAD so it
might not be doable with VBA. Seems like you would have to use VB to build
an external ActiveX Automation Object. The best thing to do is to build it
with ObjectARX and MFC. I can do it with Delphi but it is not supported by
AutoCAD.
> Miles
from
> to
> > WinAPI.
> main
> the
> > pline.
> form)
time
> > Hugo
> > draw
> > > the line. i.e.
tell
> me
> display
created
> > the
displaying
> > the
> he
> > > picks a new point?
> > > Miles Andrews
Yes, VBA allows modeless dialogs and yes you can implement [almost] any API you want in VBA. However, you will need to be using 2000i or higher.
UserForm1.Show vbModeless
(My lost reply from January 12 2003)
Instead of using a dialog, Show a modeless UserForm. You will have to explicity Close it when the user has finished drawing the line.
Now you can either have the UserForm displaying all the time, but probably you only want it to appear when the user starts drawing a line. So you may have the issue of changing the focus back to the drawing after initially Showing the UserForm. I haven't tried it but you could investigate the Activate method. Failing that you could investigate using the Windows API SetFocus. Note that this is different from (and may conflict with) the VB/VBA SetFocus method, so you should rename it as follows:
Declare Function SetFocusAPI Lib "User32" Alias "SetFocus" (ByVal hWnd As Long) As Long
Good luck, and please consider posting your final solution back here for all to enjoy!
Wayne Ivory
IT Analyst Programmer
Wespine Industries Pty Ltd
