Sheetset question
Sheetset question
Sheetset question
Why won't work the code below in Ac2k7, witch worked in Ac2k6 ?
Dim ssm As New AcSmSheetSetMgr
Set ssm = CreateObject("AcSmComponents.AcSmSheetSetMgr")
and there is no ssm created
What going wrong
Must I use getinterfaseobject?
Thanks in advance
Harrie Message was edited by: zeha
Set ssm = CreateObject("AcSmComponents.AcSmSheetSetMgr.17")
Thx for reply.
Nope. That was not the solution.
When i use the example "C:\Program Files\\Sample\ActiveX\SheetSetVBA\SheetSetVBA.dvb"
with the code
Sub Example_SSListAll()
Dim sheetset As New sheetset
' Get the sheet set manager
Dim ssMgr As New AcSmSheetSetMgr
Dim dbIter As IAcSmEnumDatabase
Dim db As IAcSmDatabase
Set dbIter = ssMgr.GetDatabaseEnumerator
then i get a automition error after the set.
I am not sure but maybe it's a unproperly installed AC2K7
I have tryed a ReInstall but that was not the clue.
Witch files where used for the Sheetset?
Regards
Harrie
