Sheet Set Manager API
Message 1 of 9
Anyone out there doing anything with the SSM?
I see how to iterate the collection of open sheet sets, but I don't see
how to tell which one is current (visible in the SSM palette).
R.K. McSwain
http://rkmcswain.blogspot.com
Replies (8)
Message 2 of 9
Yeah, I do stuff with SSM.
I've never really worried about which one was visible. I know what folder
the current drawing is saved in, and use that to determine which database I
need to be using.
R. Robert Bell
"R.K. McSwain" wrote in message
news:5441126@discussion.autodesk.com...
R.K. McSwain
Message 3 of 9
R. Robert Bell said the following On 1/4/2007 11:40 AM:
> need to be using.
Hey Robert, how's it going?
Actually since I made that post, that particular problem has become a
non-issue.
What I need to do now is search for a certain 'Sheet Set' Custom
Property and if it exists, change it.
The SSM API documentation is basically non-existent. Do you ADN guys
have access to better docs?
Thanks.
R.K. McSwain
Message 4 of 9
Agreed...the documentation is pretty weak, though there is a vba sample that
should get you pointed in the right direction.
Ie:
C:\Program Files\Autodesk Building Systems 2006\Sample\ActiveX\SheetSetVBA\
The problem i have is that I still havn't been able to return a list of all
the defined custom properties.
-Chris
news:5441291@discussion.autodesk.com...
> I
> need to be using.
non-issue.
Thanks.
R.K. McSwain
Message 5 of 9
Here is how you can get a specific custom property.
Dim allProps As AcSmCustomPropertyBag
Set allProps = mySheetSet.GetCustomPropertyBag
Dim aPropValue As AcSmCustomPropertyValue
Set aPropValue = allProps.GetProperty("Sheet Total Starting Number")
I'm not on ADN, so I don't know if they have better docs or not. Most of
what I've done is by trial-and-error, similar to what Lee when thru for his
class on SSM at AU2005. If you are just starting out with SSM customization,
I'd suggest getting that class handout.
R. Robert Bell
> I
> need to be using.
non-issue.
Thanks.
R.K. McSwain
Message 6 of 9
Have you used the GetPropertyEnumerator?
R. Robert Bell
"Chris Shoemaker" wrote in message
news:5441289@discussion.autodesk.com...
Message 7 of 9
R. Robert Bell said the following On 1/4/2007 12:39 PM:
That's exactly where I was on it, but I keep getting an error. After
seeing your code, I figured we are on the right track, so I kept going.
After a bit, I have found that this works for custom properties owned by
the "Sheet", but not those owned by the "Sheet Set"
...and the .GetProperty method expects proper case also.
Ok, I thought you were on ADN. Thanks for the reminder on the AU handout.
R.K. McSwain
Message 8 of 9
>Do you ADN guys have access to better docs?
ADN doesn't necessarily provide additional docs beyond the SDK, but it does
have a database of Questions & Answers, not too unlike this forum, that can
be searched.
Bobby C. Jones
Message 9 of 9
Yep, assuming they'd work similarly to the sheet sets themselves that was my
first try, but i seem to recall it not working.
-Chris
"R. Robert Bell" wrote in message
news:5441304@discussion.autodesk.com...
R. Robert Bell
