Setting Property (for a clueless lisper)
I want to set the arrowhead styles for dimensioning in LISP. Apparently
this is only available through VBA which I'm not very familiar with.
I want to set the style then save it as a default style (not modify an
existing dimension like the example in help).
I don't have any clue about proper syntax to use but I'm guessing it's
got to be pretty darn simple for this basic task.
Below is the basic info from the help file:
Arrowhead1Type Property
Specifies the type of arrowhead for the first end of the dimension line.
Signature
object.Arrowhead1Type
object Dim3PointAngular, DimAligned, DimAngular, DimDiametric, DimRotated
The object or objects this property applies to.
Arrowhead1Type acDimArrowheadType enum; read-write
acArrowDefault
acArrowDot
acArrowDotSmall
acArrowDotBlank
...etc...
acArrowUserDefined Read-only
System variables
This property overrides the value of the DIMBLK1 system variable for the
given dimension.
Remarks
The initial value for this property is acArrowDefault
When you use the Arrowhead1Block property to specify a block to use as a
custom arrowhead, this property will be set to acArrowUserDefined.
Here it is in html wich might format better.
Signature
DimRotated
acArrowDefault acArrowDot acArrowDotSmall acArrowDotBlank
...etc... acArrowUserDefined Read-only
System variables
given dimension.
Remarks
Sub CopyToCurrentDimStyle()
ThisDrawing.SetVariable "DIMLDRBLK", "."
ThisDrawing.ActiveDimStyle.CopyFrom ThisDrawing
End Sub
"Paul Furman" wrote in message
news:8F3BC2BF9344B9BD21EEB20A4BBC6DD4@in.WebX.maYIadrTaRb...
> Signature
> DimRotated
> System variables
> given dimension.
> Remarks
