Setting an Initial listbox value
GeeHaa
GeeHaa
Im trying to set an the default selected value of a listbox to "Model". The code highlights "Model" but the .Value and .Text properties remain blank. How do I set these to = "Model". If I select it manually it works.
LBO_Layout.AddItem ("Model")
LBO_Layout.AddItem ("Active")
Dim layout As AcadLayout
Dim layouts As AcadLayouts
Set layouts = ThisDrawing.layouts
For Each layout In layouts
If (Not (layout.Name = "Model")) Then
LBO_Layout.AddItem (layout.Name)
Next layout
LBO_Layout.Text = "Model"
GeeHaa
Never Mind
LBO_layout.Setfocus
Works
andrewpuller3811
try
        For i = 0 To LBO_Layout.ListCount - 1
            If LBO_Layout.List(i) = "Model" Then
                LBO_Layout.ListIndex = i
                Exit For
        Next i
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 11
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2023
