Set Variable for dimBlk
Hi All
How To Set .SetVariable "DIMBLK1", "_ClosedFilled" and
.SetVariable "DIMBLK2", "_ClosedFilled"
Getvariable give nothing for this variable.
Thanks for help
Amrit
norman.yuan
Have you looked at Acad help by searching "DIMBLK" or "DIMBLK1" or "DIMBLK2"?
When the default arrowhead (closed-filled arrowhead) is used in Acad, the value of System Variables "DIMBLK", "DIMBLK1" and DIMBLK2" is "" (blank string). That is why GetVariable("DIMBLK") returns "".
Read Acad's Help for more details.
Norman Yuan
Drive CAD With Code
hi norman
ok i know that is default but how to return back default value when we lost
it.
i mean to say. i change Dimblk1 to "Dot" and i play around.
now i don't have any value to Store for DimBlk1 because it return ""
now again i need to go to ClosedFilled so how can i go.
it reutrn error when we set to " ".
well, i thing there most be some way for it.
wrote in message news:6299006@discussion.autodesk.com...
"DIMBLK2"?
norman.yuan
Again, have you read/searched Acad Help? The answer is right there: to set system variable DIMBLK/DIMBLK1/DIMBLK2 back to its default "" value (closed-filled arrowhead), you enter a "." ( a dot).
Quote from Acad Help:
To return to the default, closed-filled arrowhead display, enter a single period (.).
Here is sample code
{code}
Public Sub Test()
ThisDrawing.SetVariable "DIMBLK", "_DOT"
MsgBox "->" & ThisDrawing.GetVariable("DIMBLK") & "<-"
ThisDrawing.SetVariable "DIMBLK", "."
End Sub
{code}
Norman Yuan
Drive CAD With Code
Thanks Norman
Sure i will see help file. i search in hlep also. there is no such topic
for
>single period (.).
any way thnaks a lot again. if this work this is good for me.
I really appreciate your input. Thanks.
Amrit
wrote in message news:6299043@discussion.autodesk.com...
Here is sample code
{code}
Public Sub Test()
End Sub
{code}
