Set a AutoCAD block
Set a AutoCAD block
Message 1 of 10
Set a AutoCAD block
Hello there,
can someone help mi with my VBA rule.
I just make a Excel VBA to draw 2 circles in AutoCAD.
Option Explicit
Public path As String
Public ThisDrawing As AcadDocument
Public Pos(0 To 2) As Double
Public Block_Pos(0 To 2) As Double
Public LayerRed As AcadLayer
Public Sub Kreiß()
Set ThisDrawing = AutoCAD.Documents.Add("C:\Users\Aleksandar.Jovicic.FG\Desktop\Kreiß\Kreiß.dwt")
ThisDrawing.Activate
Dim CircleRadius As Double
Dim CircleRadius_2 As Double
Dim acadCircle As Object
Dim acadBlock As Object
Dim Kreiß_bl As acadBlock
Pos(0) = 0: Pos(1) = 0: Pos(2) = 0
Block_Pos(0) = 200: Block_Pos(1) = 200: Block_Pos(2) = 0
Set Kreiß_bl = ThisDrawing.Blocks.Add(Block_Pos, "Kreiß")
CircleRadius = ActiveSheet.Range("Radius")
CircleRadius_2 = ActiveSheet.Range("Radius_innen")
Set acadCircle = ThisDrawing.ModelSpace.AddCircle(Pos, CircleRadius)
Set acadCircle = ThisDrawing.ModelSpace.AddCircle(Pos, CircleRadius_2)
AutoCAD.ZoomExtents
End Sub
Now i need to make block from this two circles ("Kreiß_bl" schuld be the block with Block_Pos)
Can you help me out?
Best regads
Alex
Replies (9)
Message 2 of 10
Alfred.NESWADBA
instead of
you should use
   Set acadCircle = Kreiß_bl.AddCircle(Pos, CircleRadius)
...to add the circle object to the block-definition (and not to the modelspace)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 10
Hello Alfred and thank you for the replay
What I muss do to add this block in Model Space with VBA?
Alex
Message 4 of 10
Alfred.NESWADBA
ThisDrawing.Modelspace.InsertBlock(...
as described >>>here<<<.
- alfred -
Alfred NESWADBA
Message 5 of 10
I have just one more question
I am using array option via excel vba
And I found this
Dim noOfObjects As Integer
Dim angleToFill As Double
Dim basePnt(0 To 2) As Double
noOfObjects = 5
angleToFill = 3.14
basePnt(0) = 0: basePnt(1) = 0: basePnt(2) = 0
Dim retObj As Variant
retObj = circleObj.ArrayPolar(noOfObjects, angleToFill, basePnt)
The problem is when I use the fill angel 360 (6.28) i have one circle less the 5
Message 6 of 10
Alfred.NESWADBA
What is the centerpoint of the circle? If it's 0,0 then ... 😉
- alfred -
Alfred NESWADBA
Message 7 of 10
Here ist the rest of the vba
Message 8 of 10
Alfred.NESWADBA
The rest I'm missing is what is the center of the circle that you then use for the array?
- alfred -
Alfred NESWADBA
Message 9 of 10
Hallo Alfred
So, ich schicke dir jetzt den ganzen VBA Code:
Option Explicit
Public Pos_2(0 To 2) As Double
Public Pos_3(0 To 2) As Double
Public Const Pi = 3.141592654
Public Sub Kreiß()
Dim CircleRadius_3 As Double
Dim acadCircle_2 As Object
Dim acadBohrung As Object
Dim circleObj As acadCircle
Dim center(0 To 2) As Double
Dim radius As Double
radius = ActiveSheet.Range("Bohrung")
center(0) = -55: center(1) = 0: center(2) = 0:
Set Kreiß_bl = ThisDrawing.Blocks.Add(Pos, "Kreiß")
CircleRadius_3 = ActiveSheet.Range("Bohrung")
Set acadCircle = Kreiß_bl.AddCircle(Pos, CircleRadius_2)
Set circleObj = Kreiß_bl.AddCircle(center, radius)
Dim blockRefObj As AcadBlockReference
Pos_3(0) = 100: Pos_3(1) = 100: Pos_3(2) = 0
Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(Pos_3, "Kreiß", 1, 1, 1, 0)
noOfObjects = ActiveSheet.Range("Anzhal")
angleToFill = 6.28
AutoCAD.ZoomExtents
End Sub
Ich versuche eine Flanche zu zeichnen. Problem ist wenn ich den "angleToFill" auf 360 bzw. 6.28 umschreibe bekomme ich einen Kreiß (Bohrung) weniger als "noOfObjects"
Message 10 of 10
Alfred.NESWADBA
well, I found out a tricky issue: when you defined 2*PI as angle to fill AutoCAD is assuming it's 0° instead of 360°, that's why the objects are all at the same position.
Strange, but reproducible.
That's how AutoCAD works, if you create an array of 5 objects from a base object it only has to create 4 objects, as the first one already exists 😉
- alfred -
Alfred NESWADBA
