Sendcommand problem
Sendcommand problem
Sendcommand problem
I'm using VB6 to send a vbarun command as follows:
mypath = VB.App.Path
acaddoc.SendCommand "-vbaload" & vbCr & mypath + "\myfile.dvb"
acaddoc.SendCommand "-vbarun" & vbCr & "myfile.dvb!mymacro" & vbCr
It seems that if the path contains any spaces they are interpreted as
returns in AutoCAD and the whole path isn't sent. Any way to handle this?
Bud
Try acaddoc.loadDVB or acadapp.loadDVB
Bud Miller had the next bright idea:
>Thanks
>Bud
You ask a silly question, you get a technical answer...
Or you could use a lisp call:
acaddoc.SendCommand "(vl-vbarun (strcat " & mypath & chr(34) &
"/myfile.dvb!mymacro" & chr(34) & ")(princ)" & vbCr
Watch for errors with the mypath string. If you have to change \ with / then
you can use this code:
Dim C1 as Integer
For C1 = 1 To Len(mypath)
If Mid(mypath, C1, 1) = "\" Then
mypath = Mid(mypath, 1, C1 - 1) & "/" & Mid(mypath, C1 + 1)
Next C1
Hope this helps,
Henk
CadFancy - Adventures in Visual Basic
www.CadFancy.myweb.nl
