sendcommand hide prompt
is there way to disable command and prompt echo during "sendcommand" session from vba?
most of app runs with vba methods, and command history and display is untouched.
but something is simply not implemented, and you need to use "sendcommand" inside app, and suddeenly, the cmd text window is full of entity selection prompts although there is no user interaction since all required entity selections are done with embedded lisp like:
Select objects: (handent "226")
it is not a big deal, but would be nice *not* to display anything while vba app is running
also, it will be nice to completely disable interactive user input while runing vba app, since all required responses are supplied through app
NOMUTT & CMDECHO (although that may be just for AutoLisp).
Dave F.
you are right, these two settings hide all except sendcommand line. so no more prompts or messages, just the pure sendcommand text as sent to autocad is displayed on cmd line
it is little bit strage that there is no centralized window command, but each submodule has its own control of display mode onto text window?
ha scritto nel messaggio news:[email protected]...
from vba?
untouched.
app is running
In these days I delighted me to look for
a valid solution to use the forms VBA with the Lisp, finding
the limited DCLs, don't allow for instance to use the multipagines thing,
what it makes the smaller and functional form.
Probably the best system is the use of the variable "USERS1" etc.
ThisDrawing.SetVariable "USERS1", TextBox1.Text
But when the form is very crowded? for which the data are many?
I have used the SendCommand, or
ThisDrawing.SendCommand "(setq pp " & TextBox1.Text & ") "
ThisDrawing.SendCommand "(setvar " & """NOMUTT""" & " 1)" & "(setq SpPiaNodi
" & SpPiaNodi & ") "
It returns
Command:(setvar "NOMUTT" 1)(setq SpPiaNodi 15) 15
it works but it is not elegant
very comfortable, but to the line of command the whole program is seen...
(setq pp etc),
how to hide this drawback?
To find a solution would open new interesting possibilities.
You can create a lisp function to call instead of just sending a lisp
expression. Then that function can contain a line of code to overwrite the
call. Something like this:
(defun somefunction (value1 value2) ; args to suit
(princ "\r "); length to suit
(setq
pp value1
SpPiaNodi value2
; and whatever else
(princ)
Then from VBA:
ThisDrawing.SendCommand "(somefunction """ & TextBox1.Text & """ """ &
SpPiaNodi & """) "
where I'm assuming that SpPiaNodi is a string variable in your VBA.
The command line will then receive something like
(somefunction "Text1" "Text2")
and the (princ "\r ") line will blank it out. Just be sure to include
enough spaces in this line to cover whatever you might send.
Ken Krupa
Autodesk Authorized Developer
Krupa CADD Solutions
www.krupacadd.com
> It returns
> (setq pp etc),
thanks
I will make some tests
carry
