SelectOnScreen Win7-64bit with Version 2011 Acad.
fxcastil
fxcastil
Has anybody used the SelectOnScreen method of creating a selection set in AutoCAD 2011.
I have been using the same VBA code in version 2005-2008 without a problem, so I am guessing the problem is with
version 2011.  This is the first time time to this VBA code in Win7-64 Bit with 2011 AutoCad.
Code snippet below
' the user is selecting text or Mtext from the screen
If strType = "Text" Then
   ReDim intFltrCode(3) As Integer
   ReDim varFltrVal(3) As Variant
      intFltrCode(0) = -4:   varFltrVal(0) = "<OR"
      intFltrCode(1) = 0:    varFltrVal(1) = "TEXT"
      intFltrCode(2) = 0:   varFltrVal(2) = "MTEXT"
      intFltrCode(3) = -4:   varFltrVal(3) = "OR>"
 ' call selection set function which creates new selection set and erases old
     Set objSelSet = ChkSelSet(strSetName)
 ' Prompts the user to select entity  from drawing based on filter
****************************  error is generated here ******************************************
         objSelSet.SelectOnScreen intFltrCode, varFltrVal
Alfred.NESWADBA
>> so I am guessing the problem is withversion 2011
Could you please tell us, what problem you do have? What error-message, at least the number?
I tried this code with AutoCAD 2011x64 (on Win7x64):
   Dim intFltrCode(0) As Integer
   Dim varFltrVal(0) As Variant
   intFltrCode(0) = 0:   varFltrVal(0) = "TEXT,MTEXT"
   Dim objSelSet As AcadSelectionSet
   Set objSelSet = ThisDrawing.SelectionSets.Add("TSTSELSET")
I did not built in the check, if a SelectionSet with this name does exist, so that has to built in.
I show how you can do an "OR"-filter without using "<OR" ..."OR>"
....and my code runs without exception. So I guess that the base of your problem is placed in that part of code you did not show (for example where the SelectionSet is created?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
fxcastil
The error message is
Run Time Error '-2147418113
AUTOMATION ERROR
CATASTROPHIC FAILURE
Alfred.NESWADBA
does my code run on your AutoCAD?
- alfred -
Alfred NESWADBA
fxcastil
I get the same error with your code as well.
Are you using you sample code inside a user-form? In other words can you use a button-click to start your lines of code?
The problem seems to be be when using a user-form to allow the operator/user to start the SelectOnScreen method.
I have read other posts about the same problem I am having.
