SelectionSet
SelectionSet
SelectionSet
Hello
In a SelectionSet, i know select all objects in the layer "MYLAYER"
In an other selectionSet, i know select all blocks named "MYBLOCK"
But i don't know select in a SelectionSet all the blocks named "MYBLOCK"
AND are ALSO in the layer "MYLAYER"
object.Select Mode[, Point1][, Point2][, FilterType][, FilterData]
How define the FilterType, and FilterData to do that
Thanks for your help
Bernard
France
Include multiple fields and they will automatically be AND'ed together. For
example, to gather all block inserts named "MYBLOCK" on layer "MYLAYER":
Dim fType(2) As Integer, fData(2) As Integer
fType(0) = 8: fData(0) = "MYLAYER"
fType(1) = 0: fData(1) = "INSERT"
fType(2) = 2: fData(2) = "MYBLOCK"
You can also use group code -4 along with OR and AND to construct more
complex filters. Look up selection set filters in the online LISP help for
detailed information.
Attitudes are contagious. Is yours worth catching?
http://www.acadx.com
"Bernard Flavignard" wrote in message
news:ef307ff.-1@WebX.SaUCah8kaAW...
> Hello
> Bernard
> France
Frank
Thank you very much for your help
I use the first method
With Lisp i use group code -4, but with VBA i don't know how to do it
Bernard
Frank Oquendo a écrit dans le message :
ef307ff.0@WebX.SaUCah8kaAW...
For
> > Hello
> > Bernard
> > France
Use it almost exactly the same way:
fType(1) = -4: fData(1) = " fType(2) = -4: fData(2) = " fType(3) = 0: fData(3) = "INSERT"
fType(4) = 2: fData(4) = "MYBLOCK"
fType(5) = -4: fData(5) = "AND>"
fType(6) = 0: fData(6) = "LINE"
fType(7) = -4: fData(7) = "OR>"
There's a routine named BuildFilter in the VB section of my web site that
might make this a little easier, just pass it two variants and your filter
values like so:
BuildFilter fType, fData, 8, "MYLAYER", -4, " "", _
0, "LINE", -4, "OR>"
Then you can use the variants (now filled with arrays) for your filter. Hope
this helps.
news:ef307ff.1@WebX.SaUCah8kaAW...
> Frank
> Bernard
Thanks Frank
Bernard
ef307ff.2@WebX.SaUCah8kaAW...
> fType(1) = -4: fData(1) = " > fType(2) = -4: fData(2) = " > fType(3) = 0: fData(3) = "INSERT"
> values like so:
> BuildFilter fType, fData, 8, "MYLAYER", -4, " > "", _
Hope
> this helps.
> > Frank
> > Bernard
