selectionset sequence problem in Autocad2008
Dose anybody know the selction sequece problem in Autocad 2008 ?
I used same VBA code with 2006 and selected object in autocad2008 using selectonScreen method.
But the object sequece in selection set is seem to 'Random' .
Can you help me ?
Dim groupCode As Variant, dataCode As Variant
Dim gpCode(0 To 0) As Integer
Dim dataValue(0 To 0) As Variant
Dim sALL As AcadSelectionSet
Set sALL = ThisDrawing.SelectionSets.Add("tempa")
sALL.Clear
gpCode(0) = 0
dataValue(0) = "Line"
groupCode = gpCode
sALL.SelectOnScreen groupCode, dataCode ' ==> Here I selected using Fence mode in autocad
For UU = 1 To sALL.Count
sALL.Item(UU - 1).Highlight True '==> but the item sequece is not match my selection sequence in autocad
Next
The DWG file structure orders
by when the elements were created.
Dose anybody know the selction sequece problem in Autocad 2008 ? I used same
method. But the object sequece in selection set is seem to 'Random' . Can you
help me ? Dim groupCode As Variant, dataCode As Variant Dim gpCode(0 To 0) As
Integer Dim dataValue(0 To 0) As Variant Dim sALL As AcadSelectionSet Set sALL
= ThisDrawing.SelectionSets.Add("tempa") sALL.Clear gpCode(0) = 0 dataValue(0)
= "Line" groupCode = gpCode sALL.SelectOnScreen groupCode, dataCode ' ==>
Here I selected using Fence mode in autocad For UU = 1 To sALL.Count
selection sequence in autocad Next
