Selection sets
Selection sets
Selection sets
The routine below was developed to erase everything in a drawing and worked beautifully in windows7 but windows10 doesn't like the Set ssetObj = statement after CREATE_SET:
Public Sub ClearDrawing()
' Clears AutoCad drawing of all objects. Used in each connection module.
Dim ssetObj As AcadSelectionSet
    On Error GoTo CREATE_SET
        ThisDrawing.SelectionSets("MSset").Delete
    GoTo SKIP_CREATE_SET
CREATE_SET:
     Set ssetObj = ThisDrawing.SelectionSets.Add("MSset")
SKIP_CREATE_SET:
    If ThisDrawing.ModelSpace.Count > 0 Then
        ReDim ssobjs(0 To ThisDrawing.ModelSpace.Count - 1) As AcadEntity
        Dim i As Integer
        For i = 0 To ThisDrawing.ModelSpace.Count - 1
        Set ssobjs(i) = ThisDrawing.ModelSpace.Item(i)
    Next
        ssetObj.AddItems ssobjs
        ssetObj.Erase
End Sub
Error code is Run-time error '91':
Object variable or With block variable not set.
Any ideas?
norman.yuan
This line of code
CREATE_SET:
should not cause error of "Object varaiable or With block variable not set", be it running in Wndow7, 8 or 10.
From my observation, your code have logic error when the drawing DOES have a SelectionSet named "MSset" (for example, when you run your code the second time, because the first run creates the SelectionSet "MSset" and does not delete it).
Follow your code carefully:
1. When the drawing has a SelectionSet names as "MSset" (created by previous running your code), these lines of code executed correctly:
That is, the SelectionSet is deleted first, and then the next line asks the code to go to "SKIP_CREATE_SET" label, thus, these lines of code are skipped:
CREATE_SET:
and directly go to the following If....End If. As you can see, in this case, ssetObj variable is NOT SET! So, this line of code raises the "91" error:
Excessively using GoTo labels in code is bad practice that leads to spaghetti code, difficult to read/follow/debug
Norman Yuan
Drive CAD With Code
Once you properly initialize the selectionset as told you by Norman, wouldn't it be simpler to use:
With ssetObj
.Select acSelectionSetAll
.Erase
End With
