Selection Set length
If u do not mind than please tell me in the program below how to calculate the length of selection set.
thanks
Private Sub cmdBt1_Click()
On Error Resume Next
Dim ss As AcadSelectionSet
Dim Pt1 As Variant
Dim Pt2 As Variant
Dim sslength As Integer
Form1.hide
Pt1 = ThisDrawing.Utility.GetPoint(, "Select First Point")
Pt2 = ThisDrawing.Utility.GetPoint(, "Select Second Point")
'create Sset object first
ss.Select acSelectionSetCrossing, Pt1, Pt2
Set ss = ThisDrawing.SelectionSets.Item("MySSet")
If ss Is Nothing Then
Set ss = ThisDrawing.SelectionSets.Add("MySSet")
sslength = AutoCAD.Application.ActiveDocument.SelectionSets.SelectionSet.count
End Sub
This is from a post I made on August 5.
Joe ...
Option Explicit
Public Sub Test()
Dim Pt1 As Variant
Dim Pt2 As Variant
Dim Sset As AcadSelectionSet
Pt1 = ThisDrawing.Utility.GetPoint(, "Select the First Point")
Pt2 = ThisDrawing.Utility.GetPoint(, "Select the Second Point")
Set Sset = ThisDrawing.SelectionSets.Add("Sset")
Sset.Select acSelectionSetCrossing, Pt1, Pt2
MsgBox "Count = " & Sset.Count
'get rid of selection set
Sset.Delete
Set Sset = Nothing
End Sub
wrote in message news:[email protected]...
thanks
Dim Pt1 As Variant
Dim Pt2 As Variant
Form1.hide
sslength =
End Sub
hi,
in the program below i am getting one error that is "The Name Selection Set Exist"
Can u tell what is that and why this problem is appearing while in the this problem is not there.
'On Error Resume Next
Dim Pt1 As Variant
Dim Pt2 As Variant
Dim Count As Integer
Form1.hide
Pt2 = ThisDrawing.Utility.GetPoint(Pt1, "Select the Second Point")
'Create Sset object first
'Form1.Show
'TxtBox1.Text = Sset.Count
Sset.Delete
Set Sset = Nothing
End Sub
hi,
IN the begning it is wroking good but later on error is coming and also nothing is highlighted in the text box1.
Please Tell me where the problem is.
thanks
Dim Pt1 As Variant
Dim Pt2 As Variant
Form1.hide
Set Sset = ThisDrawing.SelectionSets.Item("Myss")
If Sset Is Nothing Then
Set Sset = ThisDrawing.SelectionSets.Add("Myss")
Else
Sset.Clear
Form1.Show
txtbox1.Text = Str(Sset.Count)
Sset.Delete
Set Sset = Nothing
End Sub
one way is to replace
Else
Sset.Clear
with
ThisDrawing.SelectionSets.Item("Myss").delete
On Error GoTo 0
Set sset = ThisDrawing.SelectionSets.Add("Myss")
also
Form1.txtbox1.Text = Str(Sset.Count)
might be needed
hi, i am just new to VBA so please do not mind
here i want to go through the selection set and display the name every entity of the selection set please can u help.
thanks
Dim Pt1 As Variant
Dim Pt2 As Variant
Dim Eobject As AcadEntity
Form1.hide
ThisDrawing.SelectionSets.Item(Sset).Delete
On Error GoTo 0
Form1.Show
Form1.txtbox1.Text = str(Sset.Count)
'MsgBox "Count = " & Sset.Count
Unload Form1
'Type of Entities
Dim objstring As String
For Each Eobject In Sset
objstring = objstring & vbCr & Sset.Name
Next
MsgBox objstring, , "List of Selection Sets"
End Sub
Hi kulfi,
If you want to be a programmer, you are going to have to learn to do
some work and think for yourself.
Why do you expect every time you clipboard something together that
readers of this newsgroup are going to do the work for you?
I suggest you step through this code yourself with the F8 key and find
the errors and THINK about what may be causing them. Then try to fix
them yourself if you can. That way you will learn something.
If you are really stumped then post an explanation of what you did to
fix your problem and make it easier for others to help you.
Admittedly the error in the line:
may prove hard to find as you are bypassing the error in it with the line:
On Error Resume Next.
Look at the sample code you were given by Cadger and fix this error
yourself before moving on the the errors of logic and common sense in
the rest of the code. All of these will be obvious as you step through
the code.
Regards
Laurie Comerford
> thanks
> Dim Pt1 As Variant
> Dim Pt2 As Variant
> Form1.hide
> On Error GoTo 0
> Form1.Show
> Unload Form1
> 'Type of Entities
> Next
> End Sub
