Selection set from a previous selection set
I make a selection set named SelObj.
After i want to make a parzial selection set named SelParz
from my previous SelObj using the filter metod.
My wrong code:
'Make SelObj and SelParz
Set SelObj = ThisDrawing.SelectionSets.Add("TasselliLet")
Set SelParz = ThisDrawing.SelectionSets.Add("SelezioneParz")
'Select the total entity
SelObj.SelectOnScreen
'Dim and make the filter
Dim TipoFiltro(0) As Integer
Dim DatiFiltro(0) As Variant
TipoFiltro(0) = 8
DatiFiltro(0) = "Dxf1"
'My parzial selection set
SelParz.Select acSelectionSetPrevious, , , TipoFiltro, DatiFiltro
I dont want to refer previous selection but i want to refer any time at the SelObj selection set?Why?
Thx to all!
The first solution is to use the filter with the
SelectOnScreen method directly (I'm not sure what you trying to say with tha
last sentence, so this might not be an option).
The other option is to loop the entities in the
selectionset and see if they match your requirements. If this is as the code
below, it could be something like this:
Dim oEnt As AcadEntity
For Each oEnt In
SelObj
    If oEnt.Layer = "Dxf1"
Then
        ' Add it to
the other selectionset
        ' Or do
whatever you want to do to these objects directly
Next
Rune Wold
Take the dog for a walk to reply
I
metod.
My wrong code:
Set SelObj =
Set SelParz =
Dim
TipoFiltro(0) = 8
Thx to all!
