Selection set filtering
trying to erase all text or mtext on layer HL-TMP or HL-TMP2. Here is what I am using:
INTcode(0) = -4: VARvalue(0) = " INTcode(1) = 0: VARvalue(1) = "TEXT"
INTcode(2) = 0: VARvalue(2) = "MTEXT"
INTcode(3) = -4: VARvalue(3) = "OR>"
INTcode(4) = -4: VARvalue(4) = " INTcode(5) = 8: VARvalue(5) = "HL-TMP"
INTcode(6) = 8: VARvalue(6) = "HL-TMP2"
INTcode(7) = -4: VARvalue(7) = "OR>"
Set ss1 = ThisDrawing.SelectionSets("Test")
If Err Then
Err.Clear
Set ss1 = ThisDrawing.SelectionSets.Add("Test")
ss1.Clear
ss1.Select acSelectionSetAll, , , INTcode, VARvalue
ss1.Erase
but ss1 doesn't contain anything. Any ideas?
You need to and the object types with the layers. You're only using or.
Stated logically,
object type is text OR mtext AND layer is "HL-TMP" OR "HL-TMP2"
Here's a link to a function that will help you build filters.
http://www.acadx.com/visualbasic/004.htm
Ed
wrote in message news:4984224@discussion.autodesk.com...
I am using:
If Err Then
Err.Clear
ss1.Clear
ss1.Erase
Weird that my message got truncated. Here is what I am trying:
INTcode(0) = 0: VARvalue(0) = "TEXT,MTEXT"
INTcode(1) = 8: VARvalue(1) = "HL-TMP,HL-TMP2"
If Err Then
Err.Clear
ss1.Clear
ss1.Erase
This should work. What leads you to think it isn't?
wrote in message news:4984282@discussion.autodesk.com...
If Err Then
Err.Clear
ss1.Clear
ss1.Erase
my selection set contains 0 items where it should contain many.
Hmmm, I just tested this and had it dump 299 to the Immediate window.....
Sub sstest()
Dim objSS As AcadSelectionSet
Dim intCode(1) As Integer
Dim varVal(1) As Variant
On Error Resume Next
Set objSS = ThisDrawing.SelectionSets.Add("MySS")
If Err Then
Set objSS = ThisDrawing.SelectionSets.Item("MySS")
Err.Clear
intCode(0) = 0: varVal(0) = "TEXT,MTEXT"
intCode(1) = 8: varVal(1) = "BD,NOS"
objSS.Select acSelectionSetAll, , , intCode, varVal
objSS.Highlight True
Debug.Print objSS.Count
End Sub
wrote in message news:4984347@discussion.autodesk.com...
Using this exact code I am getting an:
Invalid arguement Filter Type in Select
any ideas?
