Selection Set Filter for Dyanamic Blocks?
Looking for a way to quickly get a set of all (Inserted) Dynamic Blocks, preferrably in ModelSpace only. is there a filter for this?
Or do I just use the standard block selection set filter for 'AcadBlockReference' to start, then loop back thru the selection set checking for the 'IsDynamicBlock' property?
thanks ...
gizmowiebe
You can modify the code here
http://www.visiblevisual.com/index.php/AutoCad-VBA/count-blocks.html
add something like this
Dim oBkRef As IAcadBlockReference
If oBkRef.sDynamicBlock = True Then.... 'Check if it is a dynamic block
Regards
