Selection set deleting not working
I'm trying to create a selection set, and if allready existing, delete and
recreate it, with error trapping.
The line in the Else statement doesn't seem to work, and gives no error...
Dim ssetObj As AcadSelectionSet, ssName As String
On Error Resume Next
Set ssetObj = ThisDrawing.SelectionSets.Add("TEST")
If Err.Number = 0 Then
MsgBox ("Sset created")
Else
MsgBox (Err.Description)
ssetObj.Delete
Do you get a messagebox with the description when the Else clause runs?
"Yves" wrote in message
news:5314464@discussion.autodesk.com...
Else
ssetObj.Delete
Try this:
Set ssetObj = ThisDrawing.SelectionSets.Item("TEST")
If Err Then
Err.Clear
Set ssetObj=ThisDrawing.SelectionSets.Add("TEST")
Else
ssetObj.Clear
Here's a good sample that I've always
used:
Dim ssetObj As
AcadSelectionSet
On Error Resume
Next
If Not IsNull(ThisDrawing.SelectionSets.Item("TEST_SSET"))
Then
    Set ssetObj =
ssetObj.Delete
Set ssetObj =
ThisDrawing.SelectionSets.Add("TEST_SSET")
face=Arial>---
T.W.Tan
Thanks all to the ideas,
Finally I shut down Autocad yesterday, and this
morning my code that was suppose to work, is working!!!
used:
Dim ssetObj As
AcadSelectionSet
On Error Resume
Next
Then
    Set ssetObj =
ssetObj.Delete
Set ssetObj =
face=Arial>---
T.W.Tan
