Selection Blocks
Selection Blocks
Selection Blocks
My program uses Selection Method. The help of Autocad describes the following:
object.SelectOnScreen [FilterType][, FilterData]
but I don´t know how use FilterType and FilterData to select only blocks.
Someone can help me?
Thanks.
If you do not solved this yet...
dim fitype(0) as integer
dim fidata(0) as variant
fitype(0) = 0
fdata(0) = "INSERT"
or if you need to select blocks
with attributes only:
dim fitype(1) as integer
dim fidata(1) as variant
fitype(0) = 0
fdata(0) = "INSERT"
fitype(1) = 66
fdata(1) = 1
hth
~'J'~
Thanks a lot.
Youre welcome
Happy coding
~'J'~
