Selecting the insert point of a block in vba
I have managed to work out the inserting of a block using:
Dim insertionPnt(0 To 2) As Double
Dim blockRefObj As AcadBlockReference
Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, "c:\windows\dv1a.dwg", 1#, 1#, 1#, 0)
ZoomAll
but I want to allow the user to click the screen for the location. Any help would be appreciated.
cheers
Richard
use thisdrawing.utitilty.getpoint()
method
I
    ZoomAll
cheers
Richard
this is where VBA really has its
shortcommings.
this will work for you
Dim name As String
name =
"P:\STDS\SYM\ELEC\LIGHTS\El2x4.dwg"
ThisDrawing.ActiveDocument.SendCommand
("Ortho on " & vbCrLf & "-INSERT " & name & vbCrLf &
"(command pause 1 1)" & vbCrLf & "(command pause 1
1)")
this is really using the command line to start the
block insert command.
The variable name is the name of the block you want
to insert.
I used an example from my office, change it to the
block you want
I don't know why this has not been fixed. Such a
common function can't really be completed in VBA.(or VB)
method
I
    ZoomAll
cheers
Richard
Another approach is to pick the point with a GETPOINT command, then put the
block in the drawing at that point.
The disadvantage of this approach is that you can't see an outline of the
block while you pick the insert point.
Laurie Comerford
CADApps
www.cadapps.com.au
"Mike Daugird" wrote in message
news:8E388044B68CE828378E5963B62D577F@in.WebX.maYIadrTaRb...
> this is where VBA really has its shortcommings.
> Dim name As String
> name = "P:\STDS\SYM\ELEC\LIGHTS\El2x4.dwg"
> ThisDrawing.ActiveDocument.SendCommand ("Ortho on " & vbCrLf & "-INSERT "
& name & vbCrLf & "(command pause 1 1)" & vbCrLf & "(command pause 1 1)")
> this is really using the command line to start the block insert command.
> The variable name is the name of the block you want to insert.
> I used an example from my office, change it to the block you want
> I don't know why this has not been fixed. Such a common function can't
> "Jaime" wrote in message
news:C7ACF4A2B8855F97931DC437C3E11B5B@in.WebX.maYIadrTaRb...
> use thisdrawing.utitilty.getpoint() method
> "richardm73" wrote in message
news:f0a54bd.-1@WebX.maYIadrTaRb...
> ZoomAll
> cheers
> Richard
Did everyone miss this post? is there any reason this wouldn't work for
you?
method
