Selecting object, changing color, using form
I am trying to write a VBA macro that, when I select a polyline, and then click a shortcut key (or cmd button on a form) will simply change the color of the polyline.
When I say selected, I mean highlighted with the blue boxes. (gripped?)
The following code does that, but it only works when I have the VBA editor open. When I close the editor and bind the macro to a keyboard shortcut, it doesnt work.
I would really like some code that does this:
Show form->click button to start process-> hide form->user selects a polyline->color is changed->Form reappears...or something along those lines.
Code so far:
Sub change_color_sel()
Dim pfSS As AcadSelectionSet
Dim ssobject As AutoCAD.AcadObject
'Dim ssobject As AcadEntity
Set pfSS = ThisDrawing.PickfirstSelectionSet
For Each ssobject In pfSS
ssobject.color = 2
ssobject.Update
Next
End Sub
Thanks in advance
In general, there's no reason a routine wouldn't work when bound to a
shortcut if it works in ide
however, the phrase "doesn't work" doesn't help us help you 🙂
you should trap all possible errors and include Debug.Print calls or log
events to file etc throughout any prog to see what's taking place, and where
something bombs, then get the Err.Description when it bombs so you know why
it "doesn't work"
sadly, ThisDrawing.PickfirstSelectionSet is extremely buggy...you always
have to test the return
even if you weren't using that method, you always "should" test a selection
set(or any other object for that matter) before using it...
if obj is Nothing then....problem
if obj.Count = 0 then... problem
else
'ok to proceed
depending on your version...
objects no longer have .Color property... it's .TrueColor
if you want to use a form, create a user form, put a command button on it
(name it cmd1 for instance)
Then in
Sub Cmd1_Click ()
Me.Hide
change_color_sel
Me.Show
End Sub
create a module to fire up the form
Sub Main()
dim f as MyUserForm
Set f = New MyUserForm
f.Show
Set f = Nothing
End sub
caveat to using a form in this way...
you have to use vl-vbarun to call your macro to allow you to pick on screen
while a userform is hidden
;;; however, it will crash the macro if toolbar button is clicked
;;; AND IT WILL CANCEL PICKFIRST SELECTION SET
hth
Mark
On Error GoTo ErrCtl
'Dim ssobject As AcadObject
'this is fine since a sel set can only contain entities...
'>>>> test pfSS before using....
ssobject.color = 2
ssobject.Update
Next
Exit Sub
ErrCtl:
'tells user about error but msg is volatile(gone after closing msg box)
MsgBox "Error occurred " & Err.Description
'msg less volatile but have to open ide to look in Immediate window
Debug.Print "Error occurred " & Err.Description
'non volatile...save to text file or whereever for permanent record
LogError "Error occurred " & Err.Description
Err.Clear
On Error GoTo 0
End Sub
Has it actually gone from '08?
In '07 .color can still be used but it didn't list in intellisense.
Dave F.
