Selectable/Unselectable Group
hericson
hericson
Then using AutoCAD you can switch a group selectable/unselectable in the Object grouping dialog. But how to accomplish the same thing using VBA? Any ideas? I can't found it in the Group object properties.
I was only able to do such a thing using AutoLISP code:
;;; Quickly makes non-selectable groups selectable again
(defun C:REGROUP ()
(setq grpdic (dictsearch (namedobjdict) "ACAD_GROUP") ; group dictionary
gdenam (cdar grpdic) ; g d entity name
grpnam (assoc 3 grpdic) ; group name
);setq
(if grpnam ; group found
(while grpnam ; loop thru all groups
(prompt (strcat "Group \"" (cdr grpnam) "\""))
(setq grplst (dictsearch gdenam (cdr grpnam))) ; group data
(if (= (cdr (assoc 71 grplst)) 1) ; selectability flag
(prompt " is selectable.\n")
(progn
(prompt " is not selectable. Correcting...")
(setq grplst (subst (cons 71 1) (cons 71 0) grplst))
(if (not (null (entmod grplst))) ; modify group
(prompt "done.\n")
(alert "ERROR!")
);if
);progn
);if
(setq grpdic (cddr (member grpnam grpdic))) ; next loop or group
(setq grpnam (assoc 3 grpdic))
);while
(prompt "No groups found.\n")
);if
(princ)
hericson
Thank you very much, your code worked and can be useful but at the moment I want to use VBA because my whole project is written in VBA. If I use LISP code to make a group, how to pass a group name from VBA as a parameter?
As an option I can use SendCommand like this:
ThisDrawing.SendCommand "-group" & vbCr & "selectable" & vbCr & "test_group" & vbCr & "yes" & vbCr
But this way I can't determine if the group is selectable or not.
With the LISP file loaded, you can run REGROUP as a command (use SendCommand from VBA).
Or, the LISP code could be modified to accept a parameter or two:
(defun C:REGROUP (YourParameter)
then called from SendCommand as "(C:REGROUP YourParameter)" etc.
But, like you say, it'll be somewhat difficult to pass data back and forth between VBA and AutoLISP. The only way I know of to do that is the VLAX Class for VBA. I remember it tended to crash if it was run too often. Also, I'm not even sure where you can find it anymore.
One last gasp might be to utilize the USERxxx System Variables to pass data between VBA and AutoLISP.
Does anybody else have any ideas?
