Select using XData Filter, only works with lwpolyline, is it a bug?
Message 1 of 9
I'm trying to select entities using XData, it's only working with polylines,
if the XData is attached to a different entity type, it won't work.
The following code will attach XData to any entity
Public Function AddXDATA()
Dim returnObj As AcadObject
ReDim xtype(0 To 1) As Integer
ReDim xdata(0 To 1) As Variant
Dim basePoint(0 To 2) As Double
ThisDrawing.Utility.GetEntity returnObj, basePnt, "Select an object"
xtype(0) = 1001: xdata(0) = "AAA"
xtype(1) = 1000: xdata(1) = "888"
returnObj.SetXDATA xtype, xdata
End Function
This code will only work if the above code was applied to a polyline
Public Function FindEntByXData()
Dim tempsset1 As AcadSelectionSet Dim filterType1(1) As Integer
Dim filterData1(1) As Variant
filterType1(0) = 1001: filterData1(0) = "AAA"
filterType1(1) = 1000: filterData1(1) = "888"
Set tempsset1 = acadDoc.SelectionSets.Add("SSet")
tempsset1.Clear
tempsset1.Select acSelectionSetAll, , , filterType1, filterData1
tempsset1.Delete
End Function
Your help will be deeply appreciated
Best regards
Wael Bakr
Replies (8)
Message 2 of 9
The fact that it works at all would be a bug. You cannot
filter on extended entity data, except for the application
name (1001 group).
"Wael Bakr" wrote in message
news:33DB8402915423682698CF4299337487@in.WebX.maYIadrTaRb...
> Hi,
polylines,
> End Function
> tempsset1.Clear
> tempsset1.Delete
> End Function
> Best regards
> Wael Bakr
Message 3 of 9
Hi Wael,
sure enuf, like Tony says looks like you found a bug, in that plines work
different than other objs. I only tried lwplines, lines and circles though
so there would be lots of other possibilities to check. But since "AAA" is
your "program name" then if you just make Xtype(0) and eliminate the 1000
code you'll get all the entities that have "AAA" xdata in your sel set.
Then if you want to select specific elements of data (looking for the "888"
specifically, then you can search that sel set to find those matches.
I assume since you got this far you know how to GetXdata from the items in
your sel set once you have it?
Good luck,
I'm also starting to work on some xdata routines, if I get anything working
before you do I'll let you know.
Mark
Wael Bakr wrote in message
> Hi,
polylines,
> End Function
> tempsset1.Clear
> tempsset1.Delete
> End Function
> Best regards
> Wael Bakr
Message 4 of 9
Thanks Mark, appreciate that.
At the moment I'm thinking of registering the 888 as another application and
query using both application, I hope this will be faster than searching in a
selection set.
Best regards
Wael Bakr
"MP" wrote in message
news:FC6E370C07A75EA5BB582AE2F0B38E29@in.WebX.maYIadrTaRb...
> Hi Wael,
is
"888"
> Good luck,
working
> Mark
> > Hi,
> polylines,
> > End Function
> > tempsset1.Clear
> > tempsset1.Delete
> > End Function
> > Best regards
> > Wael Bakr
Message 5 of 9
Hi Tony,
I guess you are right as this is the only explanation to it.
Thanks for your help
Best regards
Wael Bakr
"Tony Tanzillo" wrote in message
news:9BAD69E8EB1B74292DE0DAF0313E4CF0@in.WebX.maYIadrTaRb...
> name (1001 group).
> > Hi,
> polylines,
> > End Function
> > tempsset1.Clear
> > tempsset1.Delete
> > End Function
> > Best regards
> > Wael Bakr
Message 6 of 9
Hi Tony:
I was having the same problem but even on filtering
on application name only the or and and filtering
doesn't work properly.
I tried to search for a filter in this way
Dim filtertype(0 To 3) As Integer
Dim filterdata(0 To 3) As Variant
filtertype(0) = -4: filterdata(0) = " filtertype(1) = 1001: filterdata(1) = "888"
filtertype(2) = 1001: filterdata(2)="999"
filtertype(3) = -4: filterdata(3)="or>"
tempsset1.Clear
tempsset1.Select acSelectionSetAll, ,filterType,filterdata
tempsset1.count
tempsset1.delete
End Function
The tempsset1.count always is one instead of two
although i am sure that there are two entities
representing these application names.
Please any one tell me why?
Message 7 of 9
Nermeen,
see if this works
Dim dxfCode(0 to 0) as Integer
Dim dxfData(0 to 0) as Variant
dxfCode(0) = 1001
dxfData(0) = "888,999"
there are lots of posts in google regarding multi selections but I think
this is the general method
I don't know why the lisp/dxf style doesn't work in vb but I've seen this
issue talked about many times on the ng and it just doesn't seem to work for
anyone.
good luck,
Mark
"nermeen" wrote in message
news:f0e54a9.4@WebX.maYIadrTaRb...
> Hi Tony:
> filtertype(0) = -4: filterdata(0) = " > filtertype(1) = 1001: filterdata(1) = "888"
> tempsset1.Clear
> tempsset1.count
> tempsset1.delete
> End Function
Message 8 of 9
Hi Mark:
I tried this one but it also didn't work as well
as the and it seems that the filter cann't take
more than one critera.
Thanks for your concern.
Nermeen.
Message 9 of 9
Hi Mark:
I tried it again it worked but it works only with
or but i still can't make a filter combined from
or and AND.this is way it was working with me because
i was trying it with an and condition too.
Thanks for help.
