Select SelectionSet objects
I have a selection set which is created based on some filter parameters. Now i want to pass this selection set to an autolisp command.
Is there any way how to pass this as argument to autocad command prompt.
I tried a lot, but autocad vba does not seems to be providing this option at all. I think you can use the selection set created via vba is use ful only for vba commands.
any comments???
Thanks in advance
Can you post your code ?
fxcastil
search this group for" lisp selection set" to find previous posts
on this subject
http://discussion.autodesk.com/thread.jspa?messageID=387167
http://discussion.autodesk.com/thread.jspa?messageID=387725
The "Previous" selection set is the one most recently
created by a call to any of the SelectXxxx() methods
of the selection set object.
You can get it from LISP using (ssget "p")
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
wrote in message news:5065915@discussion.autodesk.com...
any comments???
Thanks in advance
