Select blocks on drawing based on attribute value and change all to specific layer
nick.atwell5H5BS
nick.atwell5H5BS
Hello!
I am fairly novice to VBA in AutoCAD but have worked with it in Excel. What I'm trying to do is select blocks on a drawing that have a specific attribute value and change those blocks to a specific layer. I know I can do this with the find command and manually changing the layers, but I need to loop through several attribute values and put each selection set on a different layer.
I've tried searching other posts to see how to do this, but my code never seems to work.
Any help is much appreciated! Thanks!
grobnik
Hi, here below a simple way to catch block and related attributes from drawing, and transfer to excel.
What you have to pay attention inside this procedure is
qq = BlkRef.GetAttributes
            For X = LBound(qq) To UBound(qq)
In this way you got block attributes which will be store in the array qq.
If you want to be sure that the block has attributes you can add
If BlkRef.HasAttributes=true then
end if
Later you can check the attribute you want to check with TAGSTRING and TEXTSTRING, respectively the Attribute Name and Value.
The attribute sequence in the array from 0 to N attribute it's the same of what you are viewing when you modify the attributes locally with form which appear double clicking on block.
               ObjExcel.ActiveSheet.Cells(1, X + 1).Value = X
               ObjExcel.ActiveSheet.Cells(2, X + 1).Value = qq(X).TagString
               ObjExcel.ActiveSheet.Cells(3, X + 1).Value = qq(X).TextString
            Next
Private Sub TemplateExcel()
Dim ObjExcel As Object
Dim xlBook As Excel.Workbook
Dim xlSheet As Excel.Worksheet
Set ObjExcel = CreateObject("Excel.Application")
Set xlBook = ObjExcel.Workbooks.Add
Set xlSheet = xlBook.Worksheets(1)
ObjExcel.Visible = True
ObjExcel.Workbooks(ObjExcel.ActiveWorkbook.Name).Activate
For Each Object In ThisDrawing.ModelSpace
    If TypeOf Object Is AcadBlockReference Or TypeOf Object Is AcadBlock Then
        Set BlkRef = Object
        If BlkRef.HasAttributes = True Then
            Nome = BlkRef.EffectiveName
            If Nome = "BLOCK NAME" Then
                BlkRef.layer="NAME OF LAYER"
            For Each MySheet In ObjExcel.Sheets
                If MySheet.Name = Nome Then
                    GoTo Qui:
            Next MySheet
            ObjExcel.ActiveSheet.Name = Nome
            Next
            ObjExcel.Sheets.Add
Qui:
    Next
End Sub
reuter.philipp
I am not sure if I understood your question correctly. If you want to run the script in AutoCAD and not in Excel and you only want to change the layer, I would do it like this:
Public Sub ChangeLayer()
    For Each ModelSpaceObject In ThisDrawing.ModelSpace
        On Error Resume Next
        If ModelSpaceObject.AttributeName = "Your Wanted Attribute" Then
            ModelSpaceObject.Layer = "Your Wanted LAyer"
        ElseIf ModelSpaceObject.AttributeName = "Your other Wanted Attribute" Then
            ModelSpaceObject.Layer = "Your other Wanted LAyer"
    Next
End Sub
Sometimes the layer "0" causes problems, that's why the On Error Resume Next, alternatively you can remove that and exclude errors directly, with an If condition if ModelSpaceObject.Name = "0", as an example.
Example of possible ModelSpaceObject Attribute:
Otherwise you can write again more precisely, where you run the script and what else you want.
With kind regards,
Philipp
norman.yuan
This is a piece of simplified code (not tested):
'' Assume you want to search attribute with given tag and given value
'' If found, change to given layer
Dim attTag As String
Dim attValue As String
Dim layerName as String
'' assume these are input values
attTag="TheAtt"
attValue="TheValue"
layerName="Layer1"
Dim ent As AcadEntity
Dim blk As acadBlockReference
'' Search block references in ModelSpace
For Each ent in ThisDrawing.ModelSpace
  If TypeOf ent Is AcadBlockReference Then
    Set blk=ent
    '' Change block reference's layer according to its attributes
    SetBlockLayer blk, attTag, attValue, layerName
Next
Private Sub SetBlockLayer(blk As AcadBlockReference, tag As String, val as String, layer As String)
  If Not blk.HasAttributes Then Exit Sub
  Dim i as Integer
  Dim att As AcadAttributeReference
  Dim atts As Variant
  atts=blk.GetAttributes()
  For i-0 to Ubound(atts)
    Set att=atts(i)
    If UCase(att.TagString)=UCase(tag) And UCase(att.TextString)=UCase(val) Then
      blk.Layer=layer
      Exit Sub
  Next
End Sub
HTH
Norman Yuan
Drive CAD With Code
