Select an object on a specific layout
I'm having trouble trying to select a block on a specific paperspace layout.
I thought I had figured it out but the code won't select any blocks. I want
to retrieve a title block on the current layout only. Here is the function
I wrote:
Public Function GetTitleBlock(tsTitleBlockSS As AcadSelectionSet) As Boolean
Dim llTitleBlockFound As Boolean
Dim laDXFCode(3) As Integer
Dim laFilterValue(3) As Variant
On Error GoTo ErrorHandler
GetTitleBlock = True
' Get the title block.
Set tsTitleBlockSS = ThisDrawing.SelectionSets.Add("TBLK_SS")
If Not tsTitleBlockSS Is Nothing Then
laDXFCode(0) = -4
laFilterValue(0) = " laDXFCode(1) = 410
laFilterValue(1) = ThisDrawing.ActiveLayout.Name
laDXFCode(2) = 2
laFilterValue(2) = "TBLO*"
laDXFCode(3) = -4
laFilterValue(3) = "and>"
tsTitleBlockSS.Select acSelectionSetAll, , , laDXFCode, laFilterValue
If tsTitleBlockSS.Count > 0 Then
Set gbTitleBlockRef = tsTitleBlockSS.Item(0)
If Not gbTitleBlockRef.HasAttributes Then
ShowErrorMessage "No attributes defined in the found title block. "
& _
"Please insert a CRA title block and try again.",
True
GetTitleBlock = False
Else
ShowErrorMessage "Unable to find a CRA standard title block in the
current drawing. " & _
True
Else
ShowErrorMessage "Unable to create selection set possibly due to low
memory " & _
"or resources. Please close some applications and try
again.", True
Exit Function
ErrorHandler:
ShowErrorMessage Err.Description, True
End Function
According to AutoDesk's DXF online reference, code 410 is the one for
layouts. All our title blocks here at work (CRA) are named starting with
the string TBLO. When I run this code from my routine in a drawing that has
two paperspace layouts and a title block on each, tsTitleBlockSS.Count
always returns 0.
Any help or suggestions would be greatly appreciated.
Stephen Fletcher
Here's one way to get there from here. Tony Tanzillo clued me in to this
technique. If you want to run the code as is, you'll need to download my
avUtils.dll. Just follow the link below. Otherwise, I've noted the changes
you'll need to make. To test this routine, I placed one instance of the
block "test" in ModelSpace, two in Layout1, and three in Layout2. Even
though that makes six references, this routine will return only the three on
Layout2.
Public Sub test()
Dim fType, fData
Dim ss As AcadSelectionSet, ss2 As AcadSelectionSet
Dim objArray() As AcadEntity, max As Long
' This section only applies if you use avUtils.dll. If not, just
manually
' define two selection sets and your filter variables
Dim obj As VBAX
Set obj = New VBAX
Set ss = obj.CreateSelectionSet
Set ss2 = obj.CreateSelectionSet("ss2")
obj.BuildFilter fType, fData, "0,INSERT,2,TEST"
max = -1
ss.Select acSelectionSetAll, , , fType, fData
For i = 0 To ss.Count - 1
If ThisDrawing.ObjectIdToObject(ss.Item(i).OwnerID).Layout.Name =
"Layout2" Then
max = max + 1
ReDim Preserve objArray(0 To max)
Set objArray(max) = ss.Item(i)
Next
ss2.AddItems objArray
Debug.Print ss2.Count
End Sub
Get free software and more at
http://msnhomepages.talkcity.com/protectionfault/foquendo
"Stephen Fletcher" wrote in message
news:87s2ai$a6410@adesknews2.autodesk.com...
layout.
want
function
Boolean
> laDXFCode(0) = -4
> laFilterValue(0) = " > laDXFCode(1) = 410
> laDXFCode(2) = 2
> laDXFCode(3) = -4
> & _
> True
> End If
> Else
> True
> End If
> Else
> memory " & _
try
> again.", True
> End If
> Exit Function
> ErrorHandler:
> End Function
has
> always returns 0.
> Stephen Fletcher
That worked!
Thanks.
Frank Oquendo wrote in message
news:87saa5$a6736@adesknews2.autodesk.com...
on
> Layout2.
> Public Sub test()
> Dim fType, fData
> manually
> Dim obj As VBAX
> Set obj = New VBAX
> max = -1
> "Layout2" Then
> max = max + 1
> End If
> Next
> End Sub
> layout.
> want
> function
> Boolean
> > laDXFCode(0) = -4
> > laFilterValue(0) = " > > laDXFCode(1) = 410
> > laDXFCode(2) = 2
> > laDXFCode(3) = -4
laFilterValue
block.
> > & _
again.",
> > True
> > End If
> > Else
> > True
> > End If
> > Else
> > memory " & _
> try
> > again.", True
> > End If
> > Exit Function
> > ErrorHandler:
> > End Function
with
> has
> > always returns 0.
> > Stephen Fletcher
In case you're interested, I added a FilterLayout method to avUtils.dll. You
feed it your selection set and a layout name you want, it'll remove all
objects from your selection set that that don't reside on the specified
layout.
news:87snje$ci829@adesknews2.autodesk.com...
> That worked!
> Thanks.
changes
three
> on
> > Layout2.
> > Public Sub test()
> > Dim fType, fData
> > manually
> > Dim obj As VBAX
> > Set obj = New VBAX
> > max = -1
> > "Layout2" Then
> > max = max + 1
> > End If
> > Next
> > End Sub
> > layout.
I
> > want
> > function
> > Boolean
> > > laDXFCode(0) = -4
> > > laFilterValue(0) = " > > > laDXFCode(1) = 410
> > > laDXFCode(2) = 2
> > > laDXFCode(3) = -4
> laFilterValue
> block.
> > > & _
> again.",
> > > True
> > > End If
> > > Else
the
again.",
> > > True
> > > End If
> > > Else
low
> > > memory " & _
and
> > try
> > > again.", True
> > > End If
> > > Exit Function
> > > ErrorHandler:
> > > End Function
> with
that
> > has
> > > always returns 0.
> > > Stephen Fletcher
