Select All Blocks in Drawing.
I've successfully selected all text on a drawing, and used the text for other functions, but I can't seem to select all blocks. Am I using the wrong filter codes?
'This Works for the Text
Set TextSS = ThisDrawing.SelectionSets.Add("TextSS")
TextSS.Clear
fType(0) = 0: fData(0) = "TEXT"
fType(1) = 67: fData(1) = "0"
TextSS.Select acSelectionSetAll, , , fType, fData
'TextSS now holds all TEXT entities in modelspace
Debug.Print TextSS.Count
To get all of the Blocks, I've tried using
fType(0) = 0: fData(0) = "INSERT" 'Get all blocks
fType(1) = -4: fData(1) = "TBS" 'Block Name
fType(3) = -4: fData(3) = "and>"
Thanks for any help 🙂
Well, after looking through the help files some more and looking through the forum, I solved my problem
fType(0) = 0
fData(0) = "Insert"
fType(1) = 2
fData(1) = "TBS"
~Cheers
gets all blocks that are the same and prints ne
john
Public Sub test()
Dim currLayer As AcadLayer
Dim layerObj As AcadLayer
Dim mtxtlabel As AcadMText
Dim strText As String
Dim dblHeight As Double
Dim dblWidth As Double
Dim dblRot As Double
Dim txtinsert As Variant
Dim strNorth As String
Dim strEast As String
dblRot = -ThisDrawing.GetVariable("VIEWTWIST")
Set layerObj = ThisDrawing.Layers.Add("C-LITE-TEXT")
layerObj.Color = acYellow
ThisDrawing.ActiveLayer = layerObj
dblWidth = 0
Dim setOBJ As AcadSelectionSet
Dim ftype(0) As Integer
Dim fdata(0) As Variant
Dim f_type As Variant
Dim f_data As Variant
Dim i As Integer
Dim pt As Variant
ftype(0) = 0
fdata(0) = "INSERT"
f_type = ftype
f_data = fdata
Set setOBJ = ThisDrawing.SelectionSets.Add("TEST2")
setOBJ.SelectOnScreen
For i = 0 To setOBJ.Count - 1
pt = setOBJ.Item(i).InsertionPoint
Dim north As String
Dim east As String
strText = "Test"
east = pt(0)
north = pt(1)
strNorthFormat = "#0.0000"
strEastFormat = "#0.0000"
strNorth = Format(north, strNorthFormat)
strEast = Format(east, strEastFormat)
strText = "N: " & (strNorth) & "\P" _
& "E: " & (strEast) & "\P" _
Set mtxtlabel = ThisDrawing.ModelSpace.AddMText(pt, dblWidth, strText)
mtxtlabel.Rotation = dblRot
MsgBox " Coords X,Y = " & pt(0) & "," & pt(1)
Next i
setOBJ.Delete
End Sub
wrote in message news:5771587@discussion.autodesk.com...
fType(0) = 0
fData(0) = "Insert"
fType(1) = 2
fData(1) = "TBS"
~Cheers
