Select 3d polylines with multiple numeric filters
Problem: Multiple numeric filters for selecting polylines. I need to select 3d polylines, which means my filters are 0 - "POLYLINE" 70 - 8 but I also need to select closed 3d polylines as well (9). I have tried -4 "" but to no avail. Also tried 70 "8,9" thinking it may be like "Line,Polyline" but that didn't work either. 70 array(8,9) but no good either Can I set up a filter that will allow multiple numeric filters or should I let the user select all polylines and scan thru the selection set for the 3d ones? Thanks, Jon
Hi Jon Use bitwise masked equals: 0 "POLYLINE" -4 "&=" 70 1 -4 "&=" 70 8 to select all closed 3d polylines... Cheers -- Juerg Menzi MENZI ENGINEERING GmbH, Switzerland http://www.menziengineering.ch
Thanks for the reply Jürg, I would like to select 3d polylines whether they are closed or open, not just closed polylines. These bitwise operators twit my brain. Regards, Jon "Jürg Menzi" wrote in message news:4166724D.CEF5E5D7@menziengineering.ch... > Hi Jon > > Use bitwise masked equals: > 0 "POLYLINE" > -4 "&=" > 70 1 > -4 "&=" > 70 8 > to select all closed 3d polylines... > > Cheers > -- > Juerg Menzi > MENZI ENGINEERING GmbH, Switzerland > http://www.menziengineering.ch
Welcome...¦-) > I would like to select 3d polylines whether they are closed or open, not > just closed polylines. (...) In this case... 0 "POLYLINE" -4 "&=" 70 8 Cheers -- Juerg Menzi MENZI ENGINEERING GmbH, Switzerland http://www.menziengineering.ch
Thanks Jürg, that worked a treat. Jon "Jürg Menzi" wrote in message news:41668358.BEF1983@menziengineering.ch... > Welcome...¦-) > > > I would like to select 3d polylines whether they are closed or open, not > > just closed polylines. (...) > In this case... > 0 "POLYLINE" > -4 "&=" > 70 8 > > Cheers > -- > Juerg Menzi > MENZI ENGINEERING GmbH, Switzerland > http://www.menziengineering.ch
Glad to help you...¦-) Cheers -- Juerg Menzi MENZI ENGINEERING GmbH, Switzerland http://www.menziengineering.ch
