Search for biggest viewport in layout
gizmowiebe
gizmowiebe
At the moment i'm creating a routine that auto fills drawing properties.
a random drawing contains different viewport and scales. I would like VBA to serach the biggest viewport and then returns the scale.
Any Ideas, It would help a lot
Thx
Wiebe
[pre]
Option Explicit
Public Function GetLargestViewport() As AcadPViewport
Dim Entity As AcadEntity
Dim FilterData(0 To 1) As Variant
Dim FilterType(0 To 1) As Integer
Dim LargestViewport As AcadPViewport
Dim LayoutViewport As AcadPViewport
Dim MaxArea As Double
Dim SelSet As AcadSelectionSet
Dim ThisArea As Double
Dim Viewport As AcadPViewport
On Error Resume Next
ThisDrawing.SelectionSets.Item("VPORTS").Delete
On Error GoTo 0
Set SelSet = ThisDrawing.SelectionSets.Add("VPORTS")
FilterType(0) = 0
FilterData(0) = "VIEWPORT"
FilterType(1) = 69
FilterData(1) = 1
SelSet.Select acSelectionSetAll, , , FilterType, FilterData
If SelSet.Count > 0 Then
Set LayoutViewport = SelSet.Item(0)
MaxArea = 0#
Set LargestViewport = Nothing
For Each Entity In ThisDrawing.PaperSpace
If TypeOf Entity Is AcadPViewport Then
Set Viewport = Entity
If Viewport.ObjectID <> LayoutViewport.ObjectID Then
ThisArea = Viewport.height * Viewport.width
If ThisArea > MaxArea Then
MaxArea = ThisArea
Set LargestViewport = Viewport
Next Entity
Set GetLargestViewport = LargestViewport
End Function
Public Sub Test()
ThisDrawing.ActiveSpace = acPaperSpace
Set Viewport = GetLargestViewport
If Viewport Is Nothing Then
MsgBox "Error"
Else
MsgBox Viewport.CustomScale
End Sub
[/pre]
