SDI / MDI
SDI / MDI
SDI / MDI
Hello ,
I develop in VBA and LISP and have the following problem:
My Autodesk (Map R5) usually works in the SDI mode.
For an exception, i activate the the MDI mode and open a second Drawing for a short time.
After the 2nd Drawing was Closed again, a trigger (in VBA create and fire, when 2nd Drawing deactivate, or first drawing becomes activate or the 2nd Drawing close) the SDI- mode turned on again.
Nevertheless although only the first Drawing exists at this moment, this Message prompted.
Only after activation the prompt in the first drawing , its possible to switch the Variable SDI to "1" again.
What I have to insert in the trigger, to turn on the SDI- mode again?
Thanks, Steffen / idp.de
On the assumption that you are opening the second drawing in order to grab
something out of it, I suggest that you can use ObjectDBX to 'open' the
drawing and never leave SDI mode...
"Make the most of the best
and the least of the worst."
Robert Louis Stevenson
http://www.acadx.com
